Home » Modeling » M2T (model-to-text transformation) » Pair up data
Pair up data [message #1729290] Tue, 12 April 2016 15:22 Go to next message
Nattapon Thathong is currently offline Nattapon ThathongFriend
I'm a newbie to Acceleo.
I have a set of json data:
"list": [
"name" : "test_1",
"type": "a"
"name" : "test_2",
"type": "b"
zd,
"name" : "test_2",
"type": "c"
I want to group the data that has the same type, for example,
test_1 and test_3 have the same type "a".
I want the output to be like ,
a: test_1, test_3
b: test_2
c: test_3
Can someone help me?
Re: Pair up data [message #1729337 is a reply to message #1729290] Wed, 13 April 2016 08:18 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
It doesn't seem like you have a model at all, so Acceleo (which only accepts EMF models as input) doesn't look like the solution for you.
If your requirements as are simple as that, all you would need is a library to parse your data (such as Gson), then simply iterate over it to store your data according to its type, then print it as you like.
If not, you will have to transform your json into an EMF model before you can use it with acceleo or another eclipse m2t project.
Laurent Goubet
Obeo
Previous Topic:[error launching acceleo]
Next Topic:Code synchronization with UML model
Current Time: Fri Mar 01 05:56:00 GMT 2024
Powered by FUDForum. Page generated in 0.02534 seconds
