Home » Eclipse Projects » Virgo » VIRGO -NANO 3.6.4 Tomcat version(VIRGO -NANO 3.6.4 Tomcat version)
VIRGO -NANO 3.6.4 Tomcat version [message #1729221] Tue, 12 April 2016 09:22 Go to next message
Chandre Gowda is currently offline Chandre GowdaFriend
Member
Recently i downloaded Virgo-Nano 3.6.4 version. However i want to know tomcat server version to which virgo nano 3.6.4 is integrated with so that i can check for websocket support.
Chandru
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729229 is a reply to message #1729221] Tue, 12 April 2016 10:05 Go to previous messageGo to next message
Violeta Georgieva is currently offline Violeta GeorgievaFriend
Apache Tomcat 7.0.61 is available with this Virgo version.
Please note that websocket implementation requires Java 7.
Violeta
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729244 is a reply to message #1729229] Tue, 12 April 2016 11:29 Go to previous messageGo to next message
Member
Thank you. Sure, we are using JDK1.7.
We use HTML5,,spring 3.x , OSGI web application deployed in Virgo nano. Request you to suggest any websocket frameworks suitable for above environment.
[Updated on: Tue, 12 April 2016 11:50]
Report message to a moderator
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729478 is a reply to message #1729244] Thu, 14 April 2016 13:14 Go to previous messageGo to next message
Member
Sorry, one more question. I also have virgo nano 3.6.2. which tomcat version is available with virgo nano 3.6.2 ?
How do we find these info
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729479 is a reply to message #1729478] Thu, 14 April 2016 13:15 Go to previous messageGo to next message
You can go to the <Virgo-Home>/repository/ext
and check the version for org.apache.catalina bundle.
Violeta
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729480 is a reply to message #1729479] Thu, 14 April 2016 13:53 Go to previous messageGo to next message
Member
No Message Body
[Updated on: Fri, 15 April 2016 05:18]
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729481 is a reply to message #1729480] Thu, 14 April 2016 14:00 Go to previous messageGo to next message
Member
We found out the jar. It was in plugins
org.apache.catalina_7.0.35.v201302131125.jar.
When i tried to deploy websocket.war in this Virgo-Nano, following error is being displayed.
WebSocket connection to 'ws://localhost:8080/websocket/ws' failed: Error during WebSocket handshake: Unexpected response code: 404
It seems websocket is not supported in this version.
So i downloaded latest virgo-nano which is 3.6.4. But this doesn't deploy .war file . Also iam not able to find 'tomcat-server.xml' to change the portno. could you please let us know on this
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729484 is a reply to message #1729481] Thu, 14 April 2016 14:36 Go to previous messageGo to next message
Member
Sorry, i downloaded virgo-nano instead of virgo-nano-web. Websocket works now Very Happy
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729604 is a reply to message #1729484] Fri, 15 April 2016 19:42 Go to previous messageGo to next message
That's great
and yes you are correct Tomcat 7.0.35 does not support JSR-356.
The first Tomcat 7 version that supports this is 7.0.47.
Re: VIRGO -NANO 3.6.4 Tomcat version [message #1729694 is a reply to message #1729604] Mon, 18 April 2016 07:55 Go to previous message
Member
Thank you very much Smile
Previous Topic:PDE OSGi bundles and Virgo tooling
Next Topic:From OSGi to Blueprints & Virgo?
Current Time: Mon Mar 30 11:34:00 GMT 2020
Powered by FUDForum. Page generated in 0.02096 seconds
