Home » Eclipse Projects » OM2M » HTTP Error 404 when running om2m on Ubuntu 12.04
HTTP Error 404 when running om2m on Ubuntu 12.04 [message #1729195] Tue, 12 April 2016 05:17 Go to next message
Wenyuan Hu is currently offline Wenyuan HuFriend
I'm new to om2m. I did clone om2m and build successfully on Ubuntu 12.04. But when I tried to run in-cse, I got error "HTTP Error 404". The detailed log is like this:
[2016-04-11 03:30:58,517 INFO] - org.eclipse.om2m.datamapping.jaxb.Activator
Starting Data Mapper
[2016-04-11 03:30:58,520 INFO] - org.eclipse.om2m.datamapping.jaxb.Activator
Registering XML Mapper Service..
[2016-04-11 03:31:00,287 INFO] - org.eclipse.om2m.datamapping.jaxb.Activator
XML Mapper service registered.
[2016-04-11 03:31:00,289 INFO] - org.eclipse.om2m.binding.http.Activator
Register HTTP RestClientService..
[2016-04-11 03:31:00,295 INFO] - org.eclipse.om2m.binding.http.Activator
HTTP RestClientService is registered.
[2016-04-11 03:31:00,297 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
Starting Persistence JPA plugin...
[2016-04-11 03:31:00,303 INFO] - org.eclipse.om2m.persistence.eclipselink.internal.DBServiceJPAImpl
Initializing Database...
[2016-04-11 03:31:00,304 INFO] - org.eclipse.om2m.persistence.eclipselink.internal.DBServiceJPAImpl
Creating new EntityManagerFactory...
[2016-04-11 03:31:02,342 INFO] - org.eclipse.om2m.persistence.eclipselink.internal.DBServiceJPAImpl
DataBase initialized.
[2016-04-11 03:31:02,364 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
Registering Database (JPA-EL) Service
[2016-04-11 03:31:02,366 INFO] - org.eclipse.om2m.binding.http.Activator
HttpService discovered
Register / context
[2016-04-11 03:31:02,424 INFO] - org.eclipse.om2m.core.Activator
Starting CSE...
DataMapper Service discovered
Add Data Mapper Service: application/xml
[2016-04-11 03:31:02,429 INFO] - org.eclipse.om2m.core.Activator
DataBase persistence service discovered
[2016-04-11 03:31:02,430 INFO] - org.eclipse.om2m.core.Activator
Rest client service discovered
[2016-04-11 03:31:02,431 INFO] - org.eclipse.om2m.core.CSEInitializer
Waiting for the database service
[2016-04-11 03:31:02,432 INFO] - org.eclipse.om2m.core.CSEInitializer
Create AccessControlPolicy resource
[2016-04-11 03:31:02,596 INFO] - org.eclipse.om2m.core.CSEInitializer
Create CSEBase resource
[2016-04-11 03:31:02,630 INFO] - org.eclipse.om2m.core.Activator
Registering CseService...
[2016-04-11 03:31:02,637 INFO] - org.eclipse.om2m.binding.http.Activator
CseService discovered
[2016-04-11 03:31:02,637 INFO] - org.eclipse.om2m.core.Activator
CSE Started
[2016-04-11 03:31:02,639 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
Register /webpage http context
[2016-04-11 03:31:02,648 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
HttpService removed
[2016-04-11 03:31:02,649 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
Unregister /webpage http context
[2016-04-11 03:31:02,649 INFO] - org.eclipse.om2m.binding.http.Activator
HttpService removed
[2016-04-11 03:31:02,650 INFO] - org.eclipse.om2m.binding.http.Activator
Unregister / http context
[2016-04-11 03:31:02,668 INFO] - org.eclipse.om2m.core.Activator
Stopping CSE
[2016-04-11 03:31:02,669 INFO] - org.eclipse.om2m.core.CSEInitializer
Sending unregistration request
[2016-04-11 03:31:02,669 INFO] - org.eclipse.om2m.core.comm.RestClient
the requestIndication RC: RequestPrimitive [operation=4,
to=http://127.0.0.1:8080/api//in-cse/in-cse,
from=admin:admin,
resultContent=0,
[2016-04-11 03:31:02,670 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
Sending request: RequestPrimitive [operation=4,
from=admin:admin,
resultContent=0,
[2016-04-11 03:31:03,813 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
Query string generated: ?rc=0
[2016-04-11 03:31:03,817 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
Request to be send: DELETE http://127.0.0.1:8080/api//in-cse/in-cse?rc=0 HTTP/1.1
Headers:
Accept:
X-M2M-Origin: admin:admin
Content-Type:
[2016-04-11 03:31:04,251 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
Http Client response: ResponsePrimitive [responseStatusCode=4004,
content=<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1"/>
<title>Error 404 ProxyServlet: /api//in-cse/in-cse</title>
</head>
<body>
<h2>HTTP ERROR: 404</h2>
<p>Problem accessing /api//in-cse/in-cse. Reason:
<pre> ProxyServlet: /api//in-cse/in-cse</pre></p>
<hr /><i><small>Powered by Jetty://</small></i>
</body>
</html>
to=admin:admin,
from=/in-cse,
[2016-04-11 03:31:04,256 INFO] - org.eclipse.om2m.core.comm.RestClient
content=<html>
<head>
</head>
<body>
</body>
</html>
to=admin:admin,
from=/in-cse,
[2016-04-11 03:31:04,259 INFO] - org.eclipse.om2m.core.CSEInitializer
Unregistration response:
content=<html>
<head>
</head>
<body>
</body>
</html>
to=admin:admin,
from=/in-cse,
[2016-04-11 03:31:04,260 INFO] - org.eclipse.om2m.binding.http.Activator
CseService removed
[2016-04-11 03:31:04,269 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
Stopping Persistence JPA plugin
[2016-04-11 03:31:04,272 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
Persistence JPA plugin stopped
[2016-04-11 22:03:21,595 INFO] - org.eclipse.om2m.datamapping.jaxb.Activator
[2016-04-11 22:03:21,596 INFO] - org.eclipse.om2m.datamapping.jaxb.Activator
[2016-04-11 22:04:10,137 INFO] - org.eclipse.om2m.datamapping.jaxb.Activator
[2016-04-11 22:04:10,195 INFO] - org.eclipse.om2m.binding.http.Activator
[2016-04-11 22:04:10,673 INFO] - org.eclipse.om2m.binding.http.Activator
[2016-04-11 22:04:10,678 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
[2016-04-11 22:04:10,719 INFO] - org.eclipse.om2m.persistence.eclipselink.internal.DBServiceJPAImpl
[2016-04-11 22:04:10,720 INFO] - org.eclipse.om2m.persistence.eclipselink.internal.DBServiceJPAImpl
[2016-04-11 22:04:43,252 INFO] - org.eclipse.om2m.persistence.eclipselink.internal.DBServiceJPAImpl
[2016-04-11 22:04:43,362 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
[2016-04-11 22:04:43,369 INFO] - org.eclipse.om2m.binding.http.Activator
[2016-04-11 22:04:43,427 INFO] - org.eclipse.om2m.binding.http.Activator
Register / context
[2016-04-11 22:04:43,972 INFO] - org.eclipse.om2m.core.Activator
Starting CSE...
[2016-04-11 22:04:43,977 INFO] - org.eclipse.om2m.core.Activator
[2016-04-11 22:04:43,979 INFO] - org.eclipse.om2m.core.Activator
[2016-04-11 22:04:43,983 INFO] - org.eclipse.om2m.core.Activator
[2016-04-11 22:04:43,996 INFO] - org.eclipse.om2m.core.CSEInitializer
[2016-04-11 22:04:44,025 INFO] - org.eclipse.om2m.core.CSEInitializer
[2016-04-11 22:04:44,238 INFO] - org.eclipse.om2m.core.CSEInitializer
[2016-04-11 22:04:44,391 INFO] - org.eclipse.om2m.core.Activator
[2016-04-11 22:04:44,568 INFO] - org.eclipse.om2m.binding.http.Activator
[2016-04-11 22:04:44,584 INFO] - org.eclipse.om2m.core.Activator
CSE Started
[2016-04-11 22:04:44,658 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
[2016-04-11 22:04:44,659 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
[2016-04-11 22:04:44,697 INFO] - org.eclipse.om2m.binding.http.Activator
HttpService removed
[2016-04-11 22:04:44,699 INFO] - org.eclipse.om2m.binding.http.Activator
[2016-04-11 22:04:44,705 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
HttpService removed
[2016-04-11 22:04:44,709 INFO] - org.eclipse.om2m.webapp.resourcesbrowser.xml.Activator
[2016-04-11 22:04:44,776 INFO] - org.eclipse.om2m.core.Activator
Stopping CSE
[2016-04-11 22:04:44,781 INFO] - org.eclipse.om2m.core.CSEInitializer
[2016-04-11 22:04:44,782 INFO] - org.eclipse.om2m.core.comm.RestClient
from=admin:admin,
resultContent=0,
[2016-04-11 22:04:44,784 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
from=admin:admin,
resultContent=0,
[2016-04-11 22:04:46,129 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
[2016-04-11 22:04:46,172 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
[2016-04-11 22:04:46,174 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
Headers:
Accept:
Content-Type:
[2016-04-11 22:04:47,220 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
content=<html>
<head>
</head>
<body>
</body>
</html>
to=admin:admin,
from=/in-cse,
[2016-04-11 22:04:47,246 INFO] - org.eclipse.om2m.core.comm.RestClient
content=<html>
<head>
</head>
<body>
</body>
</html>
to=admin:admin,
from=/in-cse,
[2016-04-11 22:04:47,361 INFO] - org.eclipse.om2m.core.CSEInitializer
content=<html>
<head>
</head>
<body>
</body>
</html>
to=admin:admin,
from=/in-cse,
[2016-04-11 22:04:47,407 INFO] - org.eclipse.om2m.binding.http.Activator
CseService removed
[2016-04-11 22:04:47,410 INFO] - org.eclipse.om2m.persistence.eclipselink.Activator
Btw, I'm running Ubuntu on VMWare virtual machine. Thanks for your answer in advance.
Re: HTTP Error 404 when running om2m on Ubuntu 12.04 [message #1729810 is a reply to message #1729195] Tue, 19 April 2016 09:14 Go to previous messageGo to next message
Francois AissaouiFriend
Member
I can see in the log that the CSE is correctly started but after that, a set of plugins are getting stopped (and mainly the http server).
Did you stop manually those plugins through the OSGi command line interface ?
Moreover, you are requesting http://127.0.0.1:8080/api and you do not have to add the "/api" at the end. If you are looking for the web page, go to http://127.0.0.1:8080/webpage
If you are still struggling, take a look at this tutorial http://wiki.eclipse.org/OM2M/one/Starting.
Re: HTTP Error 404 when running om2m on Ubuntu 12.04 [message #1730197 is a reply to message #1729810] Fri, 22 April 2016 09:25 Go to previous messageGo to next message
Hi Francois,
Thank you so much!
Actually I found the reason. It's because I didn't clone and build from scratch on Ubuntu, instead I copied a clone and build version from Windows machine to Ubuntu and did a "mvn clean install".
If I clone and build from scratch on Ubuntu, it runs perfectly.
Re: HTTP Error 404 when running om2m on Ubuntu 12.04 [message #1735854 is a reply to message #1730197] Thu, 23 June 2016 10:20 Go to previous messageGo to next message
Nithyananth Sivasubramanian is currently offline Nithyananth SivasubramanianFriend
Hi Wenyuan Hu ,
I am getting the same error as you mentioned in the last post. I am using raspberry pi3 model B board. When i tried to clone the entities using "mvn clean install " i am getting below error.
root@raspberrypi:/home/org.eclipse.om2m# mvn clan install
bash: mvn: command not found
Could you please help me to resolve the issue.
Nithyananth
Re: HTTP Error 404 when running om2m on Ubuntu 12.04 [message #1737175 is a reply to message #1735854] Wed, 06 July 2016 08:47 Go to previous messageGo to next message
Member
Hi Nithyananth,
Maven is not installed on your raspberry pi.
Install it with the following command: sudo apt-get install maven
Fran├žois
Re: HTTP Error 404 when running om2m on Ubuntu 12.04 [message #1737208 is a reply to message #1737175] Wed, 06 July 2016 12:41 Go to previous message
Mahdi Ben Alaya is currently offline Mahdi Ben AlayaFriend
Dear Nithyananth,
You are not obliged to build the project using raspberry pi since OM2M is based on pure JAVA /OSGi which can run in any JVM.
You can build the project on your machine then simply copy/past the binaries on your raspberry pi and run it.
Mahdi
Previous Topic:Building Java Application using OM2M
Next Topic:How to send sensor value to actuator plug-in
Current Time: Wed Aug 05 18:53:11 GMT 2020
Powered by FUDForum. Page generated in 0.01933 seconds
