Home » Eclipse Projects » Eclipse 4 » OOTB Eclipse 4 Application wizard "Template option" "Create sample content (parts, me
OOTB Eclipse 4 Application wizard "Template option" "Create sample content (parts, me [message #1728943] Fri, 08 April 2016 14:22 Go to next message
Paul Roubekas is currently offline Paul RoubekasFriend
Mars 4.5.2
Out of the box (OOTB) Eclipse 4 Application wizard "Template option" "Create sample content (parts, menu etc.)" has errors. See screen capture sequence below.
index.php/fa/25591/0/
index.php/fa/25592/0/
index.php/fa/25593/0/
index.php/fa/25594/0/
index.php/fa/25595/0/
The full list of errors....
Bundle 'org.eclipse.jface' cannot be resolved MANIFEST.MF /MyProject/META-INF line 10 Plug-in Problem
Bundle 'org.eclipse.swt' cannot be resolved MANIFEST.MF /MyProject/META-INF line 8 Plug-in Problem
Composite cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 38 Java Problem
EPartService cannot be resolved to a type SaveHandler.java /MyProject/src/MyProject/handlers line 21 Java Problem
EPartService cannot be resolved to a type SaveHandler.java /MyProject/src/MyProject/handlers line 29 Java Problem
FileDialog cannot be resolved to a type OpenHandler.java /MyProject/src/MyProject/handlers line 21 Java Problem
GridData cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 49 Java Problem
GridData cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 58 Java Problem
GridData cannot be resolved to a variable SamplePart.java /MyProject/src/MyProject/parts line 49 Java Problem
GridData cannot be resolved to a variable SamplePart.java /MyProject/src/MyProject/parts line 58 Java Problem
GridLayout cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 39 Java Problem
IWorkbench cannot be resolved to a type QuitHandler.java /MyProject/src/MyProject/handlers line 22 Java Problem
MessageDialog cannot be resolved AboutHandler.java /MyProject/src/MyProject/handlers line 21 Java Problem
MessageDialog cannot be resolved QuitHandler.java /MyProject/src/MyProject/handlers line 23 Java Problem
ModifyEvent cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 45 Java Problem
ModifyListener cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 43 Java Problem
Shell cannot be resolved to a type AboutHandler.java /MyProject/src/MyProject/handlers line 20 Java Problem
Shell cannot be resolved to a type OpenHandler.java /MyProject/src/MyProject/handlers line 20 Java Problem
Shell cannot be resolved to a type QuitHandler.java /MyProject/src/MyProject/handlers line 22 Java Problem
SWT cannot be resolved to a variable SamplePart.java /MyProject/src/MyProject/parts line 41 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 32 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 51 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 53 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 54 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 55 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 56 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 57 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 58 Java Problem
TableViewer cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 63 Java Problem
Text cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 31 Java Problem
Text cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 41 Java Problem
Text cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 42 Java Problem
Text cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 43 Java Problem
Text cannot be resolved to a type SamplePart.java /MyProject/src/MyProject/parts line 49 Java Problem
The import org.eclipse.e4.ui.workbench cannot be resolved QuitHandler.java /MyProject/src/MyProject/handlers line 15 Java Problem
The import org.eclipse.e4.ui.workbench cannot be resolved SaveHandler.java /MyProject/src/MyProject/handlers line 16 Java Problem
The import org.eclipse.jface cannot be resolved AboutHandler.java /MyProject/src/MyProject/handlers line 15 Java Problem
The import org.eclipse.jface cannot be resolved QuitHandler.java /MyProject/src/MyProject/handlers line 16 Java Problem
The import org.eclipse.jface cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 20 Java Problem
The import org.eclipse.swt cannot be resolved AboutHandler.java /MyProject/src/MyProject/handlers line 16 Java Problem
The import org.eclipse.swt cannot be resolved OpenHandler.java /MyProject/src/MyProject/handlers line 15 Java Problem
The import org.eclipse.swt cannot be resolved OpenHandler.java /MyProject/src/MyProject/handlers line 16 Java Problem
The import org.eclipse.swt cannot be resolved QuitHandler.java /MyProject/src/MyProject/handlers line 17 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 21 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 22 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 23 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 24 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 25 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 26 Java Problem
The import org.eclipse.swt cannot be resolved SamplePart.java /MyProject/src/MyProject/parts line 27 Java Problem
Unsatisfied version constraint: 'org.eclipse.e4.ui.workbench: 1.3.1' MANIFEST.MF /MyProject/META-INF line 12 Plug-in Problem
  • Attachment: Snap2.jpg
    (Size: 144.82KB, Downloaded 314 times)
  • Attachment: Snap3.jpg
    (Size: 228.50KB, Downloaded 363 times)
  • Attachment: Snap4.jpg
    (Size: 222.74KB, Downloaded 340 times)
  • Attachment: Snap5.jpg
    (Size: 222.54KB, Downloaded 370 times)
  • Attachment: Snap6.jpg
    (Size: 321.09KB, Downloaded 304 times)
Oxygen 3a
Windows 10
[Updated on: Sat, 09 April 2016 12:27]
Report message to a moderator
Re: OOTB Eclipse 4 Application wizard "Template option" "Create sample content (parts [message #1729011 is a reply to message #1728943] Sat, 09 April 2016 12:26 Go to previous message
The issue was the use of the e(fx)clipse plug-in target platform. See the screen capture.
index.php/fa/25598/0/
  • Attachment: Snap1.jpg
    (Size: 411.74KB, Downloaded 308 times)
Oxygen 3a
Windows 10
Previous Topic:Eclipse 3.x to E4 uplift. Could not start styling support...A null service reference is not allowed
Next Topic:How to show popup menu on customized viewer
Current Time: Thu Oct 29 00:03:09 GMT 2020
Powered by FUDForum. Page generated in 0.02282 seconds
