Home » Eclipse Projects » Eclipse Platform » ToolbarItems flicker with VisibleWhen rules
ToolbarItems flicker with VisibleWhen rules [message #1728798] Thu, 07 April 2016 12:40
Eugen Neufeld is currently offline Eugen NeufeldFriend
I have an application with a toolbar that has many items with a visibleWhen expression.
Using Eclipse 3.x the whole toolbar updates once if the conditions changes.
Using Eclipse 4.x there is "flickering" so each toolitem is removed from the toolbar separately.
As far as I can see, the difference is, that setting the visibility on the toolitem now fires an event which is executed for itself, whereas in 3x the toolbar was updated manually after all expressions were reevaluated.
Is there already a solution for this?
Eugen
Eugen Neufeld
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:Tab Sequence properties is not working properly
Next Topic:How to refresh decorations of the files in Package Explorer view
Current Time: Thu Apr 19 12:11:36 GMT 2018
Powered by FUDForum. Page generated in 0.01976 seconds
