Home » Modeling » TMF (Xtext) » [SOLVED] forbit brackets in xbase expression
[SOLVED] forbit brackets in xbase expression [message #1728744] Wed, 06 April 2016 22:21 Go to next message
Michael BudnickFriend
in my DSL I use the xbase XExpressions.
Under some conditions this expression should not allow brackets to change the order of operations.
So I will implement a @Check in my Validator-class.
How can I find out if a expression contains brackets?
I see the leftOperand and rightOperand but not if this operand is surrounded with brackets.
Thanks for any help,
Michael
[Updated on: Fri, 08 April 2016 07:16]
Report message to a moderator
Re: forbit brackets in xbase expression [message #1728831 is a reply to message #1728744] Thu, 07 April 2016 17:14 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
you may use nodemodelutils and traverse the expression.
you should not find nodes for the ( and ) keyword
Twitter : @chrdietrich
Re: forbit brackets in xbase expression [message #1728872 is a reply to message #1728831] Fri, 08 April 2016 07:15 Go to previous message
	for (leaf: NodeModelUtils.findActualNodeFor(expression).leafNodes) {
		if ('('.equals(NodeModelUtils.getTokenText(leaf))) {
			errorBrackedNotAllowed()
solved it.
Previous Topic:Mixing grammars
Next Topic:Using EmbeddedEditor or XtextStyledTextCellEditor in table view
Current Time: Tue Apr 16 18:46:18 GMT 2024
Powered by FUDForum. Page generated in 1.49540 seconds
