Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] Creating a Workspace causes certificate path issues
[EMFStore] Creating a Workspace causes certificate path issues [message #1728043] Wed, 30 March 2016 13:58 Go to next message
Joshua Hampl is currently offline Joshua HamplFriend
We are developing an application that uses a java api (restfb) to read data from facebook pages. For persistance purposes, we decided to utilize EMFStore. However, after a workspace is created:
 ESWorkspace workspace = ESWorkspaceProvider.INSTANCE.getWorkspace();
every call of the restfb api results in a SunCertPathBuilderException (see below). This error does not occur without running EMFStore.
Any suggestions and ideas are much appreciated!
com.restfb.exception.FacebookNetworkException: A network error occurred while trying to communicate with Facebook: Facebook request failed (HTTP status code null)
	at com.restfb.DefaultFacebookClient.makeRequestAndProcessResponse(DefaultFacebookClient.java:1029)
	at com.restfb.DefaultFacebookClient.makeRequest(DefaultFacebookClient.java:958)
	at com.restfb.DefaultFacebookClient.makeRequest(DefaultFacebookClient.java:921)
	at com.restfb.DefaultFacebookClient.obtainUserAccessToken(DefaultFacebookClient.java:711)
	at de.fosil.stf.sona.services.facebook.internal.FacebookService.setVerificationCode(FacebookService.java:86)
	at de.fosil.stf.sona.wizards.FBLoginWizardPage$1.changed(FBLoginWizardPage.java:48)
	at org.eclipse.swt.browser.IE$7.handleEvent(IE.java:629)
	at org.eclipse.swt.ole.win32.OleEventTable.sendEvent(OleEventTable.java:55)
	at org.eclipse.swt.ole.win32.OleEventSink.notifyListener(OleEventSink.java:152)
	at org.eclipse.swt.ole.win32.OleEventSink.Invoke(OleEventSink.java:120)
	at org.eclipse.swt.ole.win32.OleEventSink.access$1(OleEventSink.java:97)
	at org.eclipse.swt.ole.win32.OleEventSink$1.method6(OleEventSink.java:71)
	at org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMObject.java:119)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:832)
	at org.eclipse.jface.window.Window.open(Window.java:808)
	at de.fosil.stf.sona.handler.NewFacebookCommandHandler.execute(NewFacebookCommandHandler.java:17)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:247)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:229)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:149)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:825)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:701)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$6(HandledContributionItem.java:685)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:613)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
	at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
	at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302)
	at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296)
	at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1509)
	at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
	at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
	at sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
	at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
	at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:153)
	at com.restfb.DefaultWebRequestor.execute(DefaultWebRequestor.java:355)
	at com.restfb.DefaultWebRequestor.executeGet(DefaultWebRequestor.java:93)
	at com.restfb.DefaultFacebookClient$3.makeRequest(DefaultFacebookClient.java:971)
	at com.restfb.DefaultFacebookClient.makeRequestAndProcessResponse(DefaultFacebookClient.java:1027)
	... 57 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387)
	at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
	at sun.security.validator.Validator.validate(Validator.java:260)
	at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
	at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
	at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
	at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1491)
	... 71 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
	at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
	at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
	at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382)
	... 77 more
Re: [EMFStore] Creating a Workspace causes certificate path issues [message #1728419 is a reply to message #1728043] Mon, 04 April 2016 09:49 Go to previous messageGo to next message
Edgar Mueller is currently offline Edgar MuellerFriend
Hi Joshua,
this most probably happens because EMFStore ships with its own keystore
which does not contain the necessary certificate(s) for Facebook when
trying to create the SSL connection.
Could you import the respective certificates into EMFStore's keystore
(which can be found at $HOME/.emfstore/client/profiles/<YOUR_PROFILE>)
and try again? A good tool for managing Keystores via a UI is the
Keystore Explorer (http://www.keystore-explorer.org).
Hope this helps.
Edgar
Am 30.03.2016 um 17:42 schrieb Joshua Hampl:
> status code null)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 57 more
> at
> at
> at
> at
> at
> ... 71 more
> at
> at
> ... 77 more
Edgar Mueller
Get Professional Eclipse Support:
http://eclipsesource.com/en/services/developer-support/
Edgar Mueller
Get professional Eclipse developer support:
Re: [EMFStore] Creating a Workspace causes certificate path issues [message #1728442 is a reply to message #1728419] Mon, 04 April 2016 12:04 Go to previous message
Hey Edgar,
thanks for the help. We found that EMFStore changes the system properties to point to its own keystore/trustsore locations, so we changed them back for now, until we know which certificate facebook connections require.
Have a nice day!
Joshua Hampl
Previous Topic:[EMF Forms] ECPCellEditor Instantiate
Next Topic:[Edapt] Own EDataType and Factory
Current Time: Tue Aug 04 11:26:35 GMT 2020
Powered by FUDForum. Page generated in 0.02123 seconds
