Re: [DefaultDataProvider] Default file provider - Browse workspace problem [message #1728049 is a reply to message #1727931] |
Wed, 30 March 2016 15:20 |
Jonas Helming Messages: 699 Registered: July 2009 |
the Exception says, that the workspace of the Eclipse Application is not
accessible (has not been created, yet). This might be because missing
bundles of the Eclipse Platform, or several other reasons.
If you call org.eclipse.ui.PlatformUI.getWorkbench from any other place,
I think you get the same result. So this is not really related to ECP...
I am sorry, but without a detailed look, I cannot say more about this. I
would try to debug why org.eclipse.ui.PlatformUI.getWorkbench does not
work first and idenpendant of ECP, this should resolve the issue.
Jonas
Am 29.03.2016 um 16:16 schrieb Teohari Simona:
> Hi guys,
> I've made a run configuration with ECP 1.8.0 in which I insert the below
> features and of course my own ECP application plugins (model, edit,
> editor).
> org.eclipse.emf.ecp.demo.e4.feature
> org.eclipse.emf.ecp.e4.feature
> org.eclipse.emfforms.runtime.feature
> org.eclipse.emf.ecp.feature
> org.eclipse.emf.ecp.view.categorization.feature
> org.eclipse.emf.ecp.view.compoundcontrol.feature
> org.eclipse.emf.ecp.view.custom.feature
> org.eclipse.emf.ecp.view.group.feature
> org.eclipse.emf.ecp.view.horizontal.feature
> org.eclipse.emf.ecp.view.label.feature
> org.eclipse.emf.ecp.view.rule.feature
> org.eclipse.emf.ecp.view.stack.feature
> org.eclipse.emf.ecp.view.table.feature
> org.eclipse.emf.ecp.view.template.feature
> org.eclipse.emf.ecp.view.treemasterdetail.feature
> org.eclipse.emf.ecp.view.unset.feature
> org.eclipse.emf.ecp.view.validation.feature
> org.eclipse.emf.ecp.view.vertical.feature
> org.eclipse.emf.ecp.viewmodel.feature
> org.eclipse.emf.ecp.workspace.feature
> When I run the application, I try to create a project using the file
> data provider (Eclipse Workspace) by using the "Browse workspace"
> button. But when I do that, I get an error:
> java.lang.IllegalStateException: Workbench has not been created yet.
> at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
> at
> org.eclipse.ui.dialogs.WizardNewFileCreationPage.createControl(WizardNewFileCreationPage.java:244)
> at
> org.eclipse.emf.ecp.workspace.internal.ui.NewXMIFileWizardPage.createControl(NewXMIFileWizardPage.java:58)
> at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:175)
> at
> org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:705)
> at
> org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:597)
> at org.eclipse.jface.window.Window.create(Window.java:430)
> at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
> at org.eclipse.jface.window.Window.open(Window.java:792)
> at
> org.eclipse.emf.ecp.workspace.internal.ui.NewWorkspaceProjectComposite$8.widgetSelected(NewWorkspaceProjectComposite.java:316)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
> at org.eclipse.jface.window.Window.open(Window.java:803)
> at
> org.eclipse.emf.ecp.spi.ui.util.ECPHandlerHelper.createProject(ECPHandlerHelper.java:152)
> at
> org.eclipse.emf.ecp.ui.e4.handlers.NewProjectHandler.execute(NewProjectHandler.java:34)
> at
> org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
> at
> org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
> at
> org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
> at
> org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
> at
> org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
> at
> org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
> at
> org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:159)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
> I must specify that if I want to see the error from NewXMIFileWizardPage
> class I have a dialog saying "Source not found for
> org.eclipse.emf.ecp.workspace.internal.ui.NewXMIFileWizardPage ". I
> believe the org.eclipse.emf.ecp.workspace.internal.ui has the info
> hidden from all plug-ins.
> How can I solve this?
> Thank you very much,
> S.
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [DefaultDataProvider] Default file provider - Browse workspace problem [message #1728336 is a reply to message #1728160] |
Sat, 02 April 2016 08:44 |
org.eclipse.ui.PlatformUI.getWorkbench ist 3.x API, I am not sure,
whether this works in a pure e4 application. I am not sure, whether the
workspace provider of ECP works well under e4, I have never used it.
Have you tested the call indepedantly of ECP?
Best regards
Jonas
Am 31.03.2016 um 14:23 schrieb Teohari Simona:
> Hi Jonas,
> Yes, you are right, if I create a new e4 application without ECP and I
> add this code: org.eclipse.ui.PlatformUI.getWorkbench, I have the error.
> But, this is specific to e3, right? I just want to know if it is a
> problem on my side or maybe some features of the file provider
> (org.eclipse.emf.ecp.workspace.core + ui) werent completely migrated to e4.
> Thank you,
> Simona
Jonas Helming
FUDForum. Page generated in 0.03071 seconds
