Home » Modeling » TMF (Xtext) » Parse error - keyword used as parameter value
Parse error - keyword used as parameter value [message #1727692] Fri, 25 March 2016 11:33 Go to next message
Mihai Traistariu is currently offline Mihai TraistariuFriend
I'm trying to parse language where the naming convention is not very strict and the keywords can be used as parameters (name or value). I have the following dummy grammar (each statement should be on a separate line) :
grammar test.org.xtext.example.mydsl.MyDsl hidden (WS)
generate myDsl "http://www.org.test/xtext/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
	(statements+=Statement EOL+)*
	statements+=Statement EOL*
Statement:
	ImportStatement|
	RunStatement
RunStatement:
	{RunQueryStatement} 'RUN' 'PROC' parameterList+=ParameterDefinition+
ParameterDefinition:
	{VariableDefinition} paramName=ID '=' paramValue=(ID|STRING)
ImportStatement:
	{ImportProcSatatement} 'IMPORT' 'PROC' 'FROM' fileName=STRING
terminal ID:
	(!('\r'|'\n'|' '|'\t'|'"'|"'"|'='))+
terminal EOL:
	('\r'? '\n')
terminal WS :
	(' '|'\t')+
terminal STRING	:
			'"' ( '\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\'|'"') )* '"' |
			"'" ( '\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\'|"'") )* "'"
When parsing the following code :
IMPORT PROC FROM 'myfile'
RUN PROC param=PROC
I get an error on the second line "no viable alternative at input 'PROC'".
How can I change the rules to be able to parse this script?
Re: Parse error - keyword used as parameter value [message #1727694 is a reply to message #1727692] Fri, 25 March 2016 11:36 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
You can introduce a datatype rule
MyID: ID | ... | 'MyKeword' ;
And use this one instead of ID
Twitter : @chrdietrich
Re: Parse error - keyword used as parameter value [message #1727699 is a reply to message #1727694] Fri, 25 March 2016 12:13 Go to previous message
Thank you.
Previous Topic:After parsing files using xtext, Should we keep xtext emf model in the memory?
Next Topic:error in creation of new project EMF Generator Model
Current Time: Thu Apr 25 07:38:50 GMT 2024
Powered by FUDForum. Page generated in 0.02936 seconds
