Home » Eclipse Projects » NatTable » Columns are not editable
Columns are not editable [message #1727341] Tue, 22 March 2016 05:43 Go to next message
In my Nattable, there is SpanningDataLayer and on top of that ColumnHideShowLayer,SelectionLayer,ViewportLayer,FreezeLayer,CompositeFreezeLayer.
Then I add labels to Columns which should be editable and I extended AbstractRegistryConfiguration as explained in Nattable Documentation.
configRegistry.registerConfigAttribute(EditConfigAttributes.CELL_EDITABLE_RULE, IEditableRule.ALWAYS_EDITABLE,
columnLabels_editable);
configRegistry.registerConfigAttribute(EditConfigAttributes.CELL_EDITOR,new TextCellEditor(true, true),
DisplayMode.NORMAL, columnLabels_column1);
ComboBoxCellEditor comboBoxCellEditor = new ComboBoxCellEditor(values, -1);
comboBoxCellEditor.setFreeEdit(true);
configRegistry.registerConfigAttribute(EditConfigAttributes.CELL_EDITOR, comboBoxCellEditor, DisplayMode.EDIT,
columnLabels_column2);
configRegistry.registerConfigAttribute(CellConfigAttributes.CELL_PAINTER,
new CustomLineBorderDecorator(new ComboBoxPainter(),
new BorderStyle(1, GUIHelper.COLOR_BLUE, LineStyleEnum.SOLID)),
DisplayMode.NORMAL, columnLabels_column2);
I added this to nattable configuration. But the Columns are still not editable.What could be the reason?
Re: Columns are not editable [message #1727358 is a reply to message #1727341] Tue, 22 March 2016 08:09 Go to previous messageGo to next message
I suppose you are missing the required editing configurations in your NatTable. It doesn't look like you are using a GridLayer, therefore you need to add those to your composition yourself. That is also explained in the documentation.
Re: Columns are not editable [message #1727450 is a reply to message #1727358] Wed, 23 March 2016 04:41 Go to previous messageGo to next message
Hi Dirk,
Thanks for your Reply. Ja I am using CompositeLayer not GridLayer . Now I added Editconfiguration and Edit bindings in Composite Layer
CompositeLayer compositeLayer = new CompositeLayer(1, 2);
compositeLayer.setChildLayer(GridRegion.COLUMN_HEADER, columnGroupHeaderLayer, 0, 0);
compositeLayer.setChildLayer(GridRegion.BODY, compositeFreezeLayer, 0, 1);
// add edit configurations
compositeLayer.addConfiguration(new DefaultEditConfiguration());
compositeLayer.addConfiguration(new DefaultEditBindings());
Still I am not getting the Result.
Re: Columns are not editable [message #1727470 is a reply to message #1727450] Wed, 23 March 2016 05:50 Go to previous message
Hi Dirk,
it is working.
Rashmi
Previous Topic:Nattable elements are sorted after applying the filter
Next Topic:Resize one column when selected all rows
Current Time: Fri Jul 18 07:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.08047 seconds
