Home » Archived » Eclipse SmartHome » Build failed Eclipse SmartHome Model Items
Build failed Eclipse SmartHome Model Items [message #1727280] Mon, 21 March 2016 17:15 Go to next message
Julien Da Silva is currently offline Julien Da SilvaFriend
I try to build eclipse smarthome and I have a build failure, how to fix this problem?
[INFO] Reactor Summary:
[INFO]
[INFO] Eclipse SmartHome .................................. SUCCESS [ 3.759 s]
[INFO] Eclipse SmartHome Bundles .......................... SUCCESS [ 0.109 s]
[INFO] Eclipse SmartHome Test Components .................. SUCCESS [ 0.105 s]
[INFO] Eclipse SmartHome Core Components .................. SUCCESS [ 0.072 s]
[INFO] Eclipse SmartHome Core ............................. SUCCESS [ 3.082 s]
[INFO] Eclipse SmartHome Configurations ................... SUCCESS [ 0.078 s]
[INFO] Eclipse SmartHome Configuration Core ............... SUCCESS [ 1.303 s]
[INFO] Eclipse SmartHome Configuration XML ................ SUCCESS [ 0.802 s]
[INFO] Eclipse SmartHome AutoUpdate Binding ............... SUCCESS [ 0.575 s]
[INFO] Eclipse SmartHome Test ............................. SUCCESS [ 1.962 s]
[INFO] Eclipse SmartHome Configuration Dispatcher ......... SUCCESS [ 1.032 s]
[INFO] Eclipse SmartHome Configuration Core Tests ......... SUCCESS [ 5.518 s]
[INFO] Eclipse SmartHome I/O Components ................... SUCCESS [ 0.090 s]
[INFO] Eclipse SmartHome Console .......................... SUCCESS [ 0.788 s]
[INFO] Eclipse SmartHome Thing ............................ SUCCESS [ 1.269 s]
[INFO] Eclipse SmartHome Configuration Discovery .......... SUCCESS [ 0.648 s]
[INFO] Eclipse SmartHome Configuration Discovery Tests .... SUCCESS [ 11.393 s]
[INFO] Eclipse SmartHome Config XML Tests ................. SUCCESS [ 5.644 s]
[INFO] Eclipse SmartHome Sample Extension Service ......... SUCCESS [ 0.289 s]
[INFO] Eclipse SmartHome mDNS Service ..................... SUCCESS [ 0.377 s]
[INFO] Eclipse SmartHome REST Interface ................... SUCCESS [ 0.430 s]
[INFO] Eclipse SmartHome Core ID .......................... SUCCESS [ 0.385 s]
[INFO] Eclipse SmartHome Thing Tests ...................... SUCCESS [ 3.759 s]
[INFO] Eclipse SmartHome Core Tests ....................... SUCCESS [ 8.049 s]
[INFO] Eclipse SmartHome Thing Tests ...................... SUCCESS [ 10.996 s]
[INFO] Eclipse SmartHome Core Persistence ................. SUCCESS [ 0.418 s]
[INFO] Eclipse SmartHome Core Scheduler Service ........... SUCCESS [ 0.323 s]
[INFO] Eclipse SmartHome Network I/O ...................... SUCCESS [ 0.323 s]
[INFO] Eclipse SmartHome Models ........................... SUCCESS [ 0.062 s]
[INFO] Eclipse SmartHome Model Core ....................... SUCCESS [ 0.643 s]
[INFO] Eclipse SmartHome Model Lazy Generation ............ SUCCESS [ 0.599 s]
[INFO] Eclipse SmartHome Model Items ...................... FAILURE [ 12.547 s]
[INFO] Eclipse SmartHome Model Persistence ................ SKIPPED
[INFO] Eclipse SmartHome Model Script ..................... SKIPPED
[INFO] Eclipse SmartHome Core Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Core Binding XML ................. SKIPPED
[INFO] Eclipse SmartHome Core Binding XML Tests ........... SKIPPED
[INFO] Eclipse SmartHome Core Thing XML ................... SKIPPED
[INFO] Eclipse SmartHome Core Thing XML Tests ............. SKIPPED
[INFO] Eclipse SmartHome Automation ....................... SKIPPED
[INFO] Eclipse SmartHome Automation API ................... SKIPPED
[INFO] Eclipse SmartHome Automation Commands .............. SKIPPED
[INFO] Eclipse SmartHome Automation Parser GSON ........... SKIPPED
[INFO] Eclipse SmartHome Automation Providers ............. SKIPPED
[INFO] Eclipse SmartHome Automation Core .................. SKIPPED
[INFO] Eclipse SmartHome Automation Core Tests ............ SKIPPED
[INFO] Eclipse SmartHome Automation Sample JSON ........... SKIPPED
[INFO] Eclipse SmartHome Automation Core Modules .......... SKIPPED
[INFO] Eclipse SmartHome Automation Core Module Tests ..... SKIPPED
[INFO] Eclipse SmartHome Automation Timer Modules ......... SKIPPED
[INFO] Eclipse SmartHome Automation Module Timer Tests .... SKIPPED
[INFO] Eclipse SmartHome Automation Script Modules ........ SKIPPED
[INFO] Eclipse SmartHome Automation Script Default Scope .. SKIPPED
[INFO] Eclipse SmartHome Automation Script Module Tests ... SKIPPED
[INFO] Eclipse SmartHome Automation Event Tests ........... SKIPPED
[INFO] Eclipse SmartHome Automation Integration Tests ..... SKIPPED
[INFO] Eclipse SmartHome Automation Sample Extension Java . SKIPPED
[INFO] Eclipse SmartHome Automation REST API .............. SKIPPED
[INFO] Eclipse SmartHome Automation Sample REST API ....... SKIPPED
[INFO] Eclipse SmartHome Designer Bundles ................. SKIPPED
[INFO] Eclipse SmartHome Designer Core Plugin ............. SKIPPED
[INFO] Eclipse SmartHome Designer UI Plugin ............... SKIPPED
[INFO] Eclipse SmartHome Console for OSGi framework Eclipse Equinox SKIPPED
[INFO] Eclipse SmartHome Console for OSGi Console RFC 147 . SKIPPED
[INFO] Eclipse SmartHome Console for OSGi runtime Karaf ... SKIPPED
[INFO] Eclipse SmartHome Monitor .......................... SKIPPED
[INFO] Eclipse SmartHome Network I/O Tests ................ SKIPPED
[INFO] Eclipse SmartHome IO REST Tests .................... SKIPPED
[INFO] Eclipse SmartHome Core REST Interface .............. SKIPPED
[INFO] Eclipse SmartHome IO REST Core Tests ............... SKIPPED
[INFO] Eclipse SmartHome SSE Interface .................... SKIPPED
[INFO] Eclipse SmartHome IO SSE Tests ..................... SKIPPED
[INFO] Eclipse SmartHome Model Sitemap .................... SKIPPED
[INFO] Eclipse SmartHome UIs .............................. SKIPPED
[INFO] Eclipse SmartHome UI ............................... SKIPPED
[INFO] Eclipse SmartHome Sitemap REST Interface ........... SKIPPED
[INFO] Eclipse SmartHome MQTT Transport ................... SKIPPED
[INFO] Eclipse SmartHome UPnP Transport ................... SKIPPED
[INFO] Eclipse SmartHome IO UPnP Tests .................... SKIPPED
[INFO] Eclipse SmartHome Voice I/O ........................ SKIPPED
[INFO] Eclipse SmartHome Model Items Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Model Item UI .................... SKIPPED
[INFO] Eclipse SmartHome Items Model Tests ................ SKIPPED
[INFO] Eclipse SmartHome Model Persistence Runtime ........ SKIPPED
[INFO] Eclipse SmartHome Model Persistence UI ............. SKIPPED
[INFO] Eclipse SmartHome Model Persistence Tests .......... SKIPPED
[INFO] Eclipse SmartHome Model Rules ...................... SKIPPED
[INFO] Eclipse SmartHome Model Rules Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Model Script UI .................. SKIPPED
[INFO] Eclipse SmartHome Model Rules UI ................... SKIPPED
[INFO] Eclipse SmartHome Model Rules Tests ................ SKIPPED
[INFO] Eclipse SmartHome Model Script Runtime ............. SKIPPED
[INFO] Eclipse SmartHome Model Script Tests ............... SKIPPED
[INFO] Eclipse SmartHome Model Sitemap Runtime ............ SKIPPED
[INFO] Eclipse SmartHome Model Sitemap UI Plugin .......... SKIPPED
[INFO] Eclipse SmartHome Thing Model ...................... SKIPPED
[INFO] Eclipse SmartHome Thing Model Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Thing Model UI ................... SKIPPED
[INFO] Eclipse SmartHome Thing Model Tests ................ SKIPPED
[INFO] Eclipse SmartHome UI Tests ......................... SKIPPED
[INFO] Eclipse SmartHome UI Icon Support .................. SKIPPED
[INFO] Eclipse SmartHome UI Icon Tests .................... SKIPPED
[INFO] Eclipse SmartHome Storages ......................... SKIPPED
[INFO] Eclipse SmartHome MapDB Storage .................... SKIPPED
[INFO] Eclipse SmartHome Storage MapDB Tests .............. SKIPPED
[INFO] Eclipse SmartHome Extensions ....................... SKIPPED
[INFO] Eclipse SmartHome Bindings ......................... SKIPPED
[INFO] Eclipse SmartHome hue Binding ...................... SKIPPED
[INFO] Eclipse SmartHome hue Binding Tests ................ SKIPPED
[INFO] Eclipse SmartHome FSInternetRadio Binding .......... SKIPPED
[INFO] Eclipse SmartHome LIFX Binding ..................... SKIPPED
[INFO] Eclipse SmartHome NTP Binding ...................... SKIPPED
[INFO] Eclipse SmartHome Sonos Binding .................... SKIPPED
[INFO] Eclipse SmartHome WeMo Binding ..................... SKIPPED
[INFO] Eclipse SmartHome YahooWeather Binding ............. SKIPPED
[INFO] Eclipse SmartHome Transformation Services .......... SKIPPED
[INFO] Eclipse SmartHome Exec Transform Service ........... SKIPPED
[INFO] Eclipse SmartHome Javascript Transform Service ..... SKIPPED
[INFO] Eclipse SmartHome Map Transform Service ............ SKIPPED
[INFO] Eclipse SmartHome Map Transformation Service Tests . SKIPPED
[INFO] Eclipse SmartHome Scale Transform Service .......... SKIPPED
[INFO] Eclipse SmartHome Scale Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome RegEx Transform Service .......... SKIPPED
[INFO] Eclipse SmartHome RegEx Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome XPath Transform Service .......... SKIPPED
[INFO] Eclipse SmartHome XPath Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome JSonPath Transform Service ....... SKIPPED
[INFO] Eclipse SmartHome JSonPath Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome Xslt Transform Service ........... SKIPPED
[INFO] Eclipse SmartHome Xslt Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome UI Extensions .................... SKIPPED
[INFO] Eclipse SmartHome Icon Sets ........................ SKIPPED
[INFO] Eclipse SmartHome Classic Icon Set ................. SKIPPED
[INFO] Eclipse SmartHome Basic UI ......................... SKIPPED
[INFO] Eclipse SmartHome Classic UI ....................... SKIPPED
[INFO] Eclipse SmartHome Paper UI ......................... SKIPPED
[INFO] Eclipse SmartHome Features ......................... SKIPPED
[INFO] Eclipse SmartHome Runtime Core Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Model Feature ............ SKIPPED
[INFO] Eclipse SmartHome Runtime UI Feature ............... SKIPPED
[INFO] Eclipse SmartHome Runtime REST Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Automation Feature ....... SKIPPED
[INFO] Eclipse SmartHome Runtime Equinox Console Feature .. SKIPPED
[INFO] Eclipse SmartHome Runtime RfC147 Console Feature ... SKIPPED
[INFO] Eclipse SmartHome Runtime Binding Feature .......... SKIPPED
[INFO] Eclipse SmartHome Designer Dependencies ............ SKIPPED
[INFO] Eclipse SmartHome Designer Feature ................. SKIPPED
[INFO] Eclipse SmartHome Test Dependencies ................ SKIPPED
[INFO] Eclipse SmartHome Karaf Feature .................... SKIPPED
[INFO] Eclipse SmartHome Products ......................... SKIPPED
[INFO] Eclipse SmartHome Designer RCP Application ......... SKIPPED
[INFO] Eclipse SmartHome p2 Repository .................... SKIPPED
[INFO] Eclipse SmartHome Tools ............................ SKIPPED
[INFO] Eclipse SmartHome Archetypes ....................... SKIPPED
[INFO] Eclipse Smarthome Binding Archetype ................ SKIPPED
[INFO] Eclipse Smarthome Binding Archetype Testsuite ...... SKIPPED
[INFO] Eclipse SmartHome Target Platform .................. SKIPPED
[INFO] Eclipse SmartHome Distribution ..................... SKIPPED
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 02:34 min
[INFO] Finished at: 2016-03-21T18:05:50+01:00
[INFO] Final Memory: 199M/869M
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:0.23.1:compile (default-compile) on project org.eclipse.smarthome.model.item: Compilation failure: Compil
[ERROR] openhab2-master-Origin\git\smarthome\bundles\model\org.eclipse.smarthome.model.item\src-gen\org\eclipse\smarthome\model\ItemsStandaloneSetupGenerated.java:
[ERROR] return Guice.createInjector(new org.eclipse.smarthome.model.ItemsRuntimeModule());
[ERROR] ^^^^^^^^^^^^^^
Re: Build failed Eclipse SmartHome Model Items [message #1727285 is a reply to message #1727280] Mon, 21 March 2016 17:39 Go to previous messageGo to next message
Dan Cunningham is currently offline Dan CunninghamFriend
Member
Github just had a big outage, I wonder if it could not download the guava dependencies, can you try again (its back up) ?
Re: Build failed Eclipse SmartHome Model Items [message #1727325 is a reply to message #1727285] Tue, 22 March 2016 08:09 Go to previous messageGo to next message
I tried and I have the same problem.
Re: Build failed Eclipse SmartHome Model Items [message #1728188 is a reply to message #1727325] Thu, 31 March 2016 17:54 Go to previous messageGo to next message
Simon Kaufmann is currently offline Simon KaufmannFriend
Member
I bet you have Eclipse open at the same time... Switch off "Project -> Build Automatically" while you run the maven build.
Re: Build failed Eclipse SmartHome Model Items [message #1728399 is a reply to message #1728188] Mon, 04 April 2016 08:05 Go to previous messageGo to next message
Thanks, it works!
Re: Build failed Eclipse SmartHome Model Items [message #1754843 is a reply to message #1728188] Thu, 23 February 2017 04:22 Go to previous message
Steve Gao is currently offline Steve GaoFriend
Simon Kaufmann wrote on Thu, 31 March 2016 17:54
Thanks, Simon, it also works for me.
BTW, could you please share some knowledge on this issue?
Thanks a lot.
Previous Topic:Write only channel
Next Topic:Persistent data for a binding
Current Time: Fri Jan 17 15:58:00 GMT 2025
Powered by FUDForum. Page generated in 0.04718 seconds
