Home » Modeling » TMF (Xtext) » creating objects in the EMF
icon5.gif  creating objects in the EMF [message #1727099] Fri, 18 March 2016 23:17 Go to next message
Eleanor Richie is currently offline Eleanor RichieFriend
I need to create certain objects in the EMF when another objects are created. i.e if in my language I can declare a variable as an array of integers, then after this variable is declared I need to create a toString procedure in my language that takes an array of integers. So, when the user writes after that toString(myArray), he finds the toString procedure already declared for him implicitly.
a sample for the grammar :
defs:
declarations+=variables+
variables :
'var' name=ID ':' ( ('Array' '[' INTEGER ']') | 'integer' | 'string' ) ;
procedure:
'proc' name=ID '(' parameters+=ID (',' parameters+=ID)* ')'
develop :
'dev' '{'
procCall=[procedure] '(' variables+=[variables]+ ')'
This is a sample of what the language should do:
defs {
var v1 : integer
var v2 : Array[5]
var v3 : string
dev {
toString (v1) //This should be ok because a method toString is implicitly declared after the v1 is declared
toString(v2) //This should be ok because a method toString is implicitly declared after the v3 is declared
toString(v3) //This should NOT be ok bec. v3 is already a string
So I need to create a method toString that takes one variable of type integer under the declaration of v1. and when the user f3 on toString, it should go to the declaration of v1 bec. toString is not declared explicitly in the file by the user.
I have been looking into post processing but I found that it needs a lot of work to be done and I am not sure if I am going in the right direction. Can anyone guide me to how to start in making this?
Thanks Smile
Re: creating objects in the EMF [message #1727107 is a reply to message #1727099] Sat, 19 March 2016 07:00 Go to previous messageGo to next message
Anton Kosyakov is currently offline Anton KosyakovFriend
You can use a library approach to provide toString procedure: http://zarnekow.blogspot.de/2012/11/xtext-corner-8-libraries-are-key.html.
For type checking you will need custom validations: https://eclipse.org/Xtext/documentation/303_runtime_concepts.html#validation.
BTW it is impossible to say of which type should be an argument looking at a procedure.
Anton
Get professional support from the Xtext committers at www.typefox.io.
Re: creating objects in the EMF [message #1727108 is a reply to message #1727099] Sat, 19 March 2016 07:02 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi post processing is about the metaamodel. Your usecase sounds more like http://xtextcasts.org/episodes/18-model-optimization
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: creating objects in the EMF [message #1727128 is a reply to message #1727108] Sat, 19 March 2016 19:03 Go to previous messageGo to next message
Hi Anton and Christian,
I will have a look at both ways and return to you both to tell u the results.
Thanks alot Smile
Re: creating objects in the EMF [message #1727129 is a reply to message #1727107] Sat, 19 March 2016 19:06 Go to previous messageGo to next message
The link to the libraries are no longer available
Re: creating objects in the EMF [message #1727130 is a reply to message #1727129] Sat, 19 March 2016 19:11 Go to previous messageGo to next message
Hi Christian,
So, you think I should try the model optimization over the post processing right?
Re: creating objects in the EMF [message #1727137 is a reply to message #1727130] Sun, 20 March 2016 08:36 Go to previous messageGo to next message
I think you didn't get me right, I want to create an EObject of type procedure (and takes parameters and has a return type and all the grammar rule's items) and add it to the current model so that the user can use it directly. I dont want it as a feature in an existing EObject.
Re: creating objects in the EMF [message #1727154 is a reply to message #1727137] Sun, 20 March 2016 10:25 Go to previous message
No you Need the postprocessing Or a manually metamodel Or uncalled
Rules for the METAmodel and the derived State Computer for the Model 2 Model trafo
Previous Topic:Expression tree
Next Topic:Workspace Builds repeatedly when running as eclipse application
Current Time: Tue Jul 05 15:10:40 GMT 2022
Powered by FUDForum. Page generated in 0.02024 seconds
