Home » Newcomers » Newcomers » Python PyDev Virtualenvwrapper
Python PyDev Virtualenvwrapper [message #1726929] |
Thu, 17 March 2016 14:23 |
Piotr Now Messages: 2 Registered: March 2016 |
When i run debug i have some error. I think that is a problem my Virtualenv.
I changed a postactivate file in my virtualenv.
(tb_dev) piotrek-VirtualBox taskbuster_project # cd $VIRTUAL_ENV/bin
(tb_dev) piotrek-VirtualBox bin # vim postactivate
export SECRET_KEY="your_secret_django_key"
what should i to do ?
Traceback (most recent call last):
File "/var/www/taskbuster_project/manage.py", line 11, in <module>
execute_from_command_line(sys.argv)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/core/management/__init__.py", line 353, in execute_from_command_line
utility.execute()
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/core/management/__init__.py", line 345, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/core/management/__init__.py", line 195, in fetch_command
klass = load_command_class(app_name, subcommand)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/core/management/__init__.py", line 39, in load_command_class
module = import_module('%s.management.commands.%s' % (app_name, name))
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/importlib/__init__.py", line 109, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 2254, in _gcd_import
File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
File "<frozen importlib._bootstrap>", line 1129, in _exec
File "<frozen importlib._bootstrap>", line 1471, in exec_module
File "<frozen importlib._bootstrap>", line 321, in _call_with_frames_removed
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/core/management/commands/runserver.py", line 16, in <module>
from django.db.migrations.executor import MigrationExecutor
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/migrations/executor.py", line 7, in <module>
from .loader import MigrationLoader
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/migrations/loader.py", line 10, in <module>
from django.db.migrations.recorder import MigrationRecorder
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/migrations/recorder.py", line 12, in <module>
class MigrationRecorder(object):
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/migrations/recorder.py", line 26, in MigrationRecorder
class Migration(models.Model):
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/migrations/recorder.py", line 27, in Migration
app = models.CharField(max_length=255)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/models/fields/__init__.py", line 1072, in __init__
super(CharField, self).__init__(*args, **kwargs)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/db/models/fields/__init__.py", line 166, in __init__
self.db_tablespace = db_tablespace or settings.DEFAULT_INDEX_TABLESPACE
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/conf/__init__.py", line 55, in __getattr__
self._setup(name)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/conf/__init__.py", line 43, in _setup
self._wrapped = Settings(settings_module)
File "/home/piotrek/.virtualenvs/tb_dev/lib/python3.4/site-packages/django/conf/__init__.py", line 120, in __init__
raise ImproperlyConfigured("The SECRET_KEY setting must not be empty.")
django.core.exceptions.ImproperlyConfigured: The SECRET_KEY setting must not be empty.
Current Time: Thu Apr 25 10:38:17 GMT 2024
Powered by FUDForum. Page generated in 0.10038 seconds
