Home » Newcomers » Newcomers » eclipse installer problem(installer by oomph has a network problem)
eclipse installer problem [message #1726222] Thu, 10 March 2016 15:35 Go to next message
Hanna Schmidt is currently offline Hanna SchmidtFriend
Hello, I am new to this and am not sure i posted this in the right section, but i really need some help!
I cannot install eclipse on my windows 7 x64 pc, because the installer says "Network Problem - The catalog could not be loaded. Please ensure that you have network access and, if needed, have configured your network proxy."
Thing is, I AM connected to the internet, and my firewall acutally allows the .exe of this installer. (Checked it twice.) I am not running any proxy or anything of the sort I know of?
On my laptop with windows 8 (connected to the same network) everything works perfectly normal. But on my pc, I get this weird error and I dont know what is causing it. Does someone have any ideas? Sad
Thanks!
Re: eclipse installer problem [message #1726239 is a reply to message #1726222] Thu, 10 March 2016 16:40 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> network proxy."
> any proxy or anything of the sort I know of? On my laptop with windows 8
> Does someone have any ideas? :(
> Thanks!
The other option is, of course, just to download the zip file of the
Eclipse package you want and explode it in your Windows 7 filesystem
where you want it. You don't have to wait upon the formal installation
(which is only a year old or so--before that we did what I just outlined
no matter what operating system).
Re: eclipse installer problem [message #1726324 is a reply to message #1726222] Fri, 11 March 2016 12:09 Go to previous messageGo to next message
This solution does work, but even with the newest eclipse version I cannot even connect to the eclipse marketplace or establish an SVN repository connection, which I really need. It just won't connect to the internet at all and I still have no idea why it is like that. (Its not my firewall, I checked that)
Re: eclipse installer problem [message #1735216 is a reply to message #1726324] Thu, 16 June 2016 11:12 Go to previous messageGo to next message
ayal telem is currently offline ayal telemFriend
Hanna Schmidt wrote on Fri, 11 March 2016 12:09
I have the same problem.
I tried to fix it by setting the proxy for the HTTP connection, as I'm installing on a PC inside an organization's LAN, but the security guy cannot see me at the proxy. As if the Eclipse installation is not even trying to access the proxy.
So far, I'm stuck !!
Re: eclipse installer problem [message #1736250 is a reply to message #1735216] Mon, 27 June 2016 20:30 Go to previous messageGo to next message
Michael Eskin is currently offline Michael EskinFriend
Even the individual .zip file downloads are taking 12+ hours on two of my systems at two different locations, and we're seeing network failures on downloads on both. Pretty much can't install Eclipse at this point on any of our systems.
Re: eclipse installer problem [message #1740965 is a reply to message #1726222] Sun, 21 August 2016 20:17 Go to previous messageGo to next message
Rahul Bhardwaj is currently offline Rahul BhardwajFriend
How i fixed this error.
Choose the option "change network proxy" from the available options on error window.
Then, Unselect "Dynamic" and click ok.
Done.
Hope it helps.
Cheers!
Rahul
Re: eclipse installer problem [message #1740966 is a reply to message #1736250] Sun, 21 August 2016 20:18 Go to previous messageGo to next message
Done.
Re: eclipse installer problem [message #1741573 is a reply to message #1740966] Thu, 25 August 2016 22:57 Go to previous messageGo to next message
Sydney Lyon is currently offline Sydney LyonFriend
I don't see either of the above options in the installer menu.
First option is Configure Network Proxy, so I clicked that button assuming that's what you meant. It opens up this screen
index.php/fa/26882/0/
The dropdown box holds options Direct, Manual, Native.
I am also using no proxy's and have turned off my firewall to try to allow it. I'm on Windows 10.
I'm also attempting to find zip files of Neon, but if anyone can point me in the direction that would be helpful.
Re: eclipse installer problem [message #1744837 is a reply to message #1741573] Fri, 30 September 2016 16:24 Go to previous messageGo to next message
carlos eduardo is currently offline carlos eduardoFriend
Hello:
Someone would kindly tell me I can do?
Thank you very much and greetings
Carlos
Re: eclipse installer problem [message #1744841 is a reply to message #1744837] Fri, 30 September 2016 17:02 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Packages can be downloaded directly from https://www.eclipse.org/downloads/eclipse-packages/
Re: eclipse installer problem [message #1749744 is a reply to message #1726222] Sat, 10 December 2016 18:47 Go to previous messageGo to next message
Hyacinth Jade Dacalos is currently offline Hyacinth Jade DacalosFriend
Hey. I just run the installer as an administrator. Hope it helps.
  • Attachment: Capture.PNG
    (Size: 63.18KB, Downloaded 3435 times)
icon13.gif  Re: eclipse installer problem [message #1749790 is a reply to message #1749744] Mon, 12 December 2016 10:28 Go to previous messageGo to next message
David Wilson is currently offline David WilsonFriend
Same problem here, and I am already running it as an Administrator (MacOS, Sierra).
Re: eclipse installer problem [message #1749796 is a reply to message #1749790] Mon, 12 December 2016 11:57 Go to previous messageGo to next message
Watch this. He explained everything. Hope it helps. https://youtu.be/47yY1uCTU0M
Re: eclipse installer problem [message #1761294 is a reply to message #1749796] Tue, 09 May 2017 13:46 Go to previous messageGo to next message
Allan Pomeroy is currently offline Allan PomeroyFriend
Hi folks. Unfortunately this problem persists. None of the posts above allow the installer to work. I always get the error listed above.
I'm on a Mac inside a corporate firewall. Thanks for any help.
Re: eclipse installer problem [message #1768221 is a reply to message #1726222] Fri, 14 July 2017 19:45 Go to previous messageGo to next message
Christian Otting is currently offline Christian OttingFriend
Hey, I had the same problem, seems like setting the Active Provider to "direct" did the trick for me.
Re: eclipse installer problem [message #1780033 is a reply to message #1741573] Tue, 16 January 2018 16:05 Go to previous messageGo to next message
Sailesh Chaurasia is currently offline Sailesh ChaurasiaFriend
please help regarding my problem
Re: eclipse installer problem [message #1784201 is a reply to message #1726222] Fri, 23 March 2018 13:27 Go to previous messageGo to next message
Gustavo Ibanez is currently offline Gustavo IbanezFriend
I solved this problem by disabling antivirus
Re: eclipse installer problem [message #1790711 is a reply to message #1784201] Thu, 14 June 2018 17:51 Go to previous messageGo to next message
Jay Chetty is currently offline Jay ChettyFriend
I solved it by removing the SOCKS Host setting. This was on Ubuntu 16.04 with no anti-virus.
Re: eclipse installer problem [message #1804486 is a reply to message #1726222] Tue, 26 March 2019 19:53 Go to previous messageGo to next message
james fanelli is currently offline james fanelliFriend
I have tried all of these solutions and nothing works.
Pls help
Re: eclipse installer problem [message #1808276 is a reply to message #1726222] Thu, 20 June 2019 22:21 Go to previous messageGo to next message
Don Kleppinger is currently offline Don KleppingerFriend
I had same problem but I discovered that I needed the http_proxy https_proxy and ftp_proxy settings exported to my environment. It already was when I log into my linux user home account but was not when I switched to root by su -. So I had to re-export those proxy settings as root. And then it worked
Re: eclipse installer problem [message #1809863 is a reply to message #1808276] Thu, 25 July 2019 02:50 Go to previous messageGo to next message
Harry Nye is currently offline Harry NyeFriend
I am having the catalogue error when I attempt to use the installer regardless that, at home, I only have a DSL modem between me and the internet...no proxy
I downloaded an Eclipse ZIP file but I do not see an executable in there only jar files. May I have some help with this, please?
Harry
Re: eclipse installer problem [message #1809869 is a reply to message #1808276] Thu, 25 July 2019 06:00 Go to previous messageGo to next message
No Message Body
Re: eclipse installer problem [message #1809870 is a reply to message #1809869] Thu, 25 July 2019 06:07 Go to previous messageGo to next message
I get the same error, I have windows 10 , I disabled the firewall, changed from to direct as I do not have a proxy server. I downloaded the zip file but I cannot find an exe file
Re: eclipse installer problem [message #1809876 is a reply to message #1809870] Thu, 25 July 2019 08:36 Go to previous messageGo to next message
The installer is trying to download this file:
http://www.eclipse.org/setups/setups.zip
If that fails for whatever reason (and you don't have an older version in the cache because it's never succeeded before), this dialog will come up. Are you able to access that URL via your browser?
Ed Merks
Re: eclipse installer problem [message #1809919 is a reply to message #1809876] Thu, 25 July 2019 16:37 Go to previous messageGo to next message
I can access the site no problem and I downloaded the zip file. I don't have a older version in cache.
Re: eclipse installer problem [message #1809920 is a reply to message #1809919] Thu, 25 July 2019 16:39 Go to previous messageGo to next message
and thanks for replying, Ed. Might you be able to help me with the ZIP file? I have not been able to find an exe file in there
Re: eclipse installer problem [message #1809924 is a reply to message #1809920] Thu, 25 July 2019 18:14 Go to previous messageGo to next message
The *.exe will be in in the folder eclipse/eclipse.exe wherever you unzip it.
Ed Merks
Re: eclipse installer problem [message #1809937 is a reply to message #1809924] Thu, 25 July 2019 21:49 Go to previous messageGo to next message
Thanks Ed, however, there is not an exe file contained in the zip file located here: http://www.eclipse.org/setups/setups.zip, is this the right file location?
Re: eclipse installer problem [message #1809942 is a reply to message #1809937] Fri, 26 July 2019 03:47 Go to previous messageGo to next message
I assumed you were trying to download one of the packages that you can unzip:
The setups.zip is just the catalog from which you can choose which package you want to install, but if you can't download that, it's likely you'll have other network problems (downloading the artifacts that need to be installed) even if you could download the catalog.
Ed Merks
Re: eclipse installer problem [message #1809964 is a reply to message #1809942] Fri, 26 July 2019 15:07 Go to previous messageGo to next message
Thanks Ed. Malware was preventing me from installing the app. It is working now. I saw nothing in the forum about malware being a culprit preventing installation so this is good info, I think, for all others like me.
Thanks for your patience.
Harry
Re: eclipse installer problem [message #1809981 is a reply to message #1809964] Sat, 27 July 2019 04:35 Go to previous messageGo to next message
Thanks for sharing your findings for the benefit of the next person who might run into this problem.
Ed Merks
Re: eclipse installer problem [message #1811326 is a reply to message #1726222] Sat, 31 August 2019 03:00 Go to previous messageGo to next message
Chinazor Agummadu is currently offline Chinazor AgummaduFriend
Hello, newbie here. I'm also having this issue and I don't quite understand what I'm supposed to do to fix it.
Re: eclipse installer problem [message #1814022 is a reply to message #1811326] Mon, 02 September 2019 00:56 Go to previous messageGo to next message
download Malwarebytes and scan your computer and follow prompts, maybe disable your virus scanner before running malwarebytes
Re: eclipse installer problem [message #1824148 is a reply to message #1726222] Wed, 08 April 2020 15:30 Go to previous messageGo to next message
Tudor Rosca is currently offline Tudor RoscaFriend
I was getting this when trying to install inside a VM with a particular proxy configuration.
I found that if I update the HTTP and HTTPS to match the "Manual Proxy Setup " from my VM settings, by adding the Address and Port, and selecting the option which had HTTP, HTTPS ticked (I forgot which of the 3 that was, I think Manual) , I was able to get rid of the error.
Re: eclipse installer problem [message #1827481 is a reply to message #1726222] Fri, 15 May 2020 13:13 Go to previous messageGo to next message
Yalin Meric is currently offline Yalin MericFriend
Didn't work in my remote desktop which is connected to company network. I use VPN to connect to it. It works fine in my laptop connected to my home network. I have never seen that with any other app. We developers already have enough to deal with so that is really an unnecessary and annoying issue. I shouldn't spend time trying to figure out proxy settings to install an app.
Re: eclipse installer problem [message #1827487 is a reply to message #1827481] Fri, 15 May 2020 14:50 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
There are plenty of company policies limiting the Internet accesses when there is a VPN running. This is to prevent sneak paths around the company firewall, but all the policies are not exactly to the point, they often limit more than is necessary.
Tauno Voipio
[Updated on: Fri, 15 May 2020 14:50]
Report message to a moderator
Re: eclipse installer problem [message #1827826 is a reply to message #1827487] Mon, 25 May 2020 07:37 Go to previous messageGo to next message
tomas platz is currently offline tomas platzFriend
Hi everyone. Thanks for all your advices. I tried almost everything and now it works.
Work hard have fun
Essays for sale
Re: eclipse installer problem [message #1828683 is a reply to message #1726222] Tue, 16 June 2020 14:24 Go to previous messageGo to next message
Charles Doucette is currently offline Charles DoucetteFriend
Make sure you disconnect from any VPNs.
Re: eclipse installer problem [message #1831440 is a reply to message #1828683] Wed, 19 August 2020 21:01 Go to previous messageGo to next message
JYOTHEESH Ramannagari is currently offline JYOTHEESH RamannagariFriend
Thanks, this works
Re: eclipse installer problem [message #1833900 is a reply to message #1831440] Tue, 27 October 2020 10:49 Go to previous messageGo to next message
Anne Warren is currently offline Anne WarrenFriend
When I'm trying to install, it needs permission. After pressing Yes, it's showing nothing. what is the problem? I can't understand.
Re: eclipse installer problem [message #1833905 is a reply to message #1833900] Tue, 27 October 2020 14:33 Go to previous messageGo to next message
You're trying not run the installer *.exe; it doesn't need permission to run. Or are you trying to unzip package the *.zip? If the latter, trying using https://www.7-zip.org/ because the Windows unzip is kind of brain dead.
Ed Merks
Re: eclipse installer problem [message #1839444 is a reply to message #1833905] Sun, 21 March 2021 17:20 Go to previous messageGo to next message
Rodrigo Ximenes is currently offline Rodrigo XimenesFriend
GO TO Change Networks setings
ON THE LABEL "Active Provider" CLICK ON the dropdown and select any option where the dynamic on the list will be unchecked.
Re: eclipse installer problem [message #1849724 is a reply to message #1726222] Mon, 31 January 2022 09:33 Go to previous message
logeswaran s is currently offline logeswaran sFriend
youtu.be/noCbvdlKKWQ
refer this video link
it will fix the issue by downloading direct packages
eclipse.org/downloads/packages/
Previous Topic:Red Squares instead of most view icons
Next Topic:Birt with XAMPP
Current Time: Thu Apr 25 17:21:01 GMT 2024
Powered by FUDForum. Page generated in 0.09895 seconds
