Home » Modeling » TMF (Xtext) » Call functions from other files
Call functions from other files [message #1725711] Mon, 07 March 2016 08:46 Go to next message
Josselin Kerdraon is currently offline Josselin KerdraonFriend
I'm developing a grammar where user will be able to declare functions in the editor or in other files. I would like this editor to be able to recognize when the user call a function developed in another file.
The idea I had for the grammar validation part was to copy function declarations in the editor's text, but hidden of this editor.
For example:
//Part hidden
def addition (var a, var b, var c){
        c=a+b;
//Part typed by the user in the editor
var a=1;
var b=2;
var c=0;
addition(a,b,c);
I tried to use the setVisibleRegion of my editor's viewer, but it doesn't work.
How could I do that ?
Re: Call functions from other files [message #1725723 is a reply to message #1725711] Mon, 07 March 2016 10:02 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
i dont get that.
in xtext by default named things from one file is visible from other files.
so you want need this hidden thing at all
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Mon, 07 March 2016 10:09]
Report message to a moderator
Re: Call functions from other files [message #1725731 is a reply to message #1725723] Mon, 07 March 2016 10:29 Go to previous messageGo to next message
So how do I import script written in other files to my editor (an implicit import ) ?
Re: Call functions from other files [message #1725736 is a reply to message #1725731] Mon, 07 March 2016 10:53 Go to previous messageGo to next message
By default you have to do nothing. How does your grammar and scoping look
like
Re: Call functions from other files [message #1725754 is a reply to message #1725736] Mon, 07 March 2016 12:45 Go to previous messageGo to next message
Well, currently I can't test other files because the data files manager is not working yet. So I just supposed that files created would not be detected in the editor.
Function part of my grammar looks like this:
CalcDeclaration  returns newFunction:
	'def' name=STR '('inParameters+=InVariable (',' inParameters+=InVariable )* (',' outParameters+=OutVariable)* ')' '{'
		instructions+=Instruction*
FunctionCall:
	functionName=[newFunction|STR] '('(arguments+=[Assignable|STR] ',')*  arguments+=[Assignable|STR] ')'
My ScopeProvider is currently empty.
Re: Call functions from other files [message #1725759 is a reply to message #1725754] Mon, 07 March 2016 13:19 Go to previous messageGo to next message
this should work fine if both files are in the same project (in eclipse) or in the same resourceset standalone.
Re: Call functions from other files [message #1725760 is a reply to message #1725759] Mon, 07 March 2016 13:27 Go to previous messageGo to next message
They are in the same project but not in the same eclipse plugin
I mean, this application will store files containing functions. This files will be managed by a plugin (and stored in a ftp server).
In this application there are GEF components used to display values. This values can be calculated programmatically with an editor using a language (with xtext). You think that these editors will be able to find automatically the functions written in the files ?
[Updated on: Mon, 07 March 2016 13:34]
Re: Call functions from other files [message #1725764 is a reply to message #1725760] Mon, 07 March 2016 13:39 Go to previous messageGo to next message
if you adapt the scoping accordingly. and or create the resourceset properly (have no idea what you exactly do)
Re: Call functions from other files [message #1725768 is a reply to message #1725764] Mon, 07 March 2016 14:02 Go to previous messageGo to next message
It's a big project so it's difficult to explain but:
A manager plugin provides files containing functions written with my grammar to be loaded.
My editor's plugin can access to this manager. So I want that, when I open an editor, files are read and function references are created. The goal is: when I write a function call in the editor, it's validated when the function is in one of this file.
I'm trying to see how to adapt scoping
[Updated on: Mon, 07 March 2016 14:02]
Re: Call functions from other files [message #1725774 is a reply to message #1725768] Mon, 07 March 2016 14:45 Go to previous messageGo to next message
Du you use embedded editor?
Re: Call functions from other files [message #1725777 is a reply to message #1725774] Mon, 07 March 2016 15:10 Go to previous messageGo to next message
Yes and I initialize it like this:
        EmbeddedEditorFactory factory = injector.getInstance(EmbeddedEditorFactory.class);
        final EmbeddedEditor handle = factory.newEditor(resourceProvider).showErrorAndWarningAnnotations().withParent(composite);
        final EmbeddedEditorModelAccess partialEditor = handle.createPartialEditor(true);
        ScriptStandaloneSetup.doSetup();
        if (script != null) {
            String s = script.toString().trim().replaceAll("[;]", ";\n").replaceAll("[{]", "{\n");
            handle.getDocument().set(script.toString());
            handle.getViewer().setVisibleRegion(0, script.toString().length());
        } else {
            handle.getDocument().set("\n");
            handle.getViewer().setVisibleRegion(0, 1);
Re: Call functions from other files [message #1725780 is a reply to message #1725777] Mon, 07 March 2016 15:14 Go to previous messageGo to next message
then i think it is the best to have all in the same file.
you can tweak the visible part using
EmbeddedEditorModelAccess.setModel(XtextDocument document, String prefix, String editablePart, String suffix)
Re: Call functions from other files [message #1725790 is a reply to message #1725780] Mon, 07 March 2016 16:39 Go to previous message
I don't have a good version of Xtext (there is no setModel, just updateModel...). But it works perfectly by using updatePrefix. So my problem is fixed
Thanks for your help Christian Wink
Previous Topic:Create xmi file in runtime through saving
Next Topic:Different prefix for Special Character in RuleCall
Current Time: Fri Oct 22 19:15:39 GMT 2021
Powered by FUDForum. Page generated in 0.02571 seconds
