Cannot import (local) Git repository [message #1725445] |
Thu, 03 March 2016 14:47 |
Harry Houdini Messages: 142 Registered: February 2010 |
I am using Linux Ubuntu 15.04, Eclipse 4.5.2 (Mars.2) and EGit 4.1.1.
I don't succeed to clone a Python repository from EGit through SSH.
Here are the steps :
1. Import...
2. Git / Projects from Git
3. Existing local repository
4. Import using the New Project wizard
5. Finish
6. PyDev Project
7. Setting project name, interpreter...
8. Next -> Finish
Then I get an error Windows :
Connecting Git team provider failed. See log for details.
org.eclipse.core.runtime.CoreException
Here is the log from .metadata/.log :
!ENTRY org.eclipse.egit.ui 4 0 2016-03-03 15:22:37.832
!MESSAGE Connecting Git team provider failed. See log for details.
!STACK 1
org.eclipse.core.runtime.CoreException: Connecting Git team provider failed. See log for details.
at org.eclipse.egit.core.op.ConnectProviderOperation.execute(ConnectProviderOperation.java:111)
at org.eclipse.egit.ui.internal.clone.GitImportWizard$8.run(GitImportWizard.java:286)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2225)
at org.eclipse.egit.ui.internal.clone.GitImportWizard.importProjects(GitImportWizard.java:291)
at org.eclipse.egit.ui.internal.clone.GitImportWizard.access$2(GitImportWizard.java:235)
at org.eclipse.egit.ui.internal.clone.GitImportWizard$4.run(GitImportWizard.java:205)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Contains: Error connecting project DevTools, no Git repositories found
!SUBENTRY 1 org.eclipse.egit.core 4 0 2016-03-03 15:22:37.832
!SUBENTRY 2 org.eclipse.egit.core 4 0 2016-03-03 15:22:37.834
!MESSAGE Error connecting project DevTools, no Git repositories found
When I import as a General Project (instead of a PyDev project), it does work...
[Updated on: Thu, 03 March 2016 14:48] Report message to a moderator
FUDForum. Page generated in 0.03451 seconds
