Home » Eclipse Projects » BPMN 2.0 Modeler » Custom Task
Custom Task [message #1725336] Wed, 02 March 2016 10:47 Go to next message
I have a problem Sad. I have updated my eclipse and now i do not see into "Palette" Custom Task. someone can help me? My version eclipse is: Luna Service Release 2 (4.4.2)
Thanks Smile
Re: Custom Task [message #1725342 is a reply to message #1725336] Wed, 02 March 2016 13:28 Go to previous messageGo to next message
Hi Salvatore,
Which version of the editor did you update to? I'm assuming you still have the WorkItemDefinitions.wid file in your project folder?
Bob
Re: Custom Task [message #1725729 is a reply to message #1725336] Mon, 07 March 2016 05:28 Go to previous messageGo to next message
I'm seeing the same bug here on Eclipse 4.5.2 and BPMN2 modeler 1.2.3.
Also tried renaming the .wid file to WorkItemDefinitions.wid and updating the reference in 'drools.rulebase.conf' to
drools.workDefinition = WorkItemDefinitions.wid
Without any effect sadly. Same problem in another environment with Eclipse Mars and BPMN2 Plugin v1.2.1.
Espen
EDIT: Updated typo in version: 1.2.3-Final version of the plugin.
[Updated on: Tue, 08 March 2016 03:48] by Moderator
Re: Custom Task [message #1725971 is a reply to message #1725729] Tue, 08 March 2016 12:22 Go to previous message
Yes, this is a known issue (please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=488221) and we're working feverishly on fixing this. The editor does not pay attention to the drools.rulebase.conf file, so it will not find your wid files referenced therein. In the meantime, please make sure the wid file is located in the root of your Eclipse project directory.
Previous Topic:add a new workflow pattern bpmn 2.0
Current Time: Fri May 23 14:31:46 EDT 2025
Powered by FUDForum. Page generated in 0.03511 seconds
