Re: Diagram refresh problem [message #1725148 is a reply to message #1724545] |
Tue, 01 March 2016 09:27 |
Thanks Adam for that submission.
Could you please raise a bug in sirius so that this issue is handle
correctly.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Laurent
Le 24/02/2016 15:43, Adam Lengyel a écrit :
> During a debugging phase I found the fallowings:
> - plugin: org.eclipse.sirius.diagram.ui (3.1.2.201511030845)
> - package: org.eclipse.sirius.diagram.ui.internal.refresh
> - class: GMFHelper
> - method: getGraphicalEditPart(View)
> In this method please check this part (line 646-648):
> if (dialectEditor instanceof DiagramEditor && ((DiagramEditor)
> editor).getDiagram() != diagram) {
> diagramEditor = (DiagramEditor) dialectEditor;
> Maybe instead of editor, you should use dialectEditor and instead of !=
> you should use ==, like below:
> dialectEditor).getDiagram() == diagram) {
> I ran into a situation, where editor contained a non DiagramEditor
> instance, and in that case the line 646 led to a ClassCastException.
> Adam
Laurent Fasani - Obeo
FUDForum. Page generated in 0.03247 seconds
