Home » Archived » Hudson » Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist => solved(Hudson Maven3 Plugin version 3.0.5 and maven 3.3.x -> Missing file mvn.bat when starting build)
icon14.gif  Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist => solved [message #1723968] Fri, 19 February 2016 10:26 Go to next message
Denis Schettl is currently offline Denis SchettlFriend
I did some regression-test for maven 3.3.9 and hudson 3.3.3. My old bug 463047 still exist.
When I start an maven-build on an windows-build-client i get the error that the file mvn.bat do not exist. Maven has changed the mvn.bat to mvn.cmd for the 3.3.x-Versions.
Test-Environment:
Hudson-Master: Oracle Linux 6.7 + Hudson 3.3.3 + Maven3-Plugin 3.0.5 + Oracle Java 1.8.0_73-b02 (64 bit)
Build-Client: Win7 (Started via JNLP-Agent) + Java 1.6.0_45_b06 (or java 1.8.0_73-b02)
Please can you reopen 463047 and fix this error? My developers want to change to maven 3.3.9, but without hudson-support I am not able to support this maven version ...
Thanks for help
Denis
[Updated on: Mon, 22 February 2016 06:56]
Report message to a moderator
Re: Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist [message #1724010 is a reply to message #1723968] Fri, 19 February 2016 18:06 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
Ah I see, it is fixed for maven plugin 3.0.6, but not released yet. I'll release it as soon as possible and upload to plugin central
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist [message #1724011 is a reply to message #1724010] Fri, 19 February 2016 19:24 Go to previous messageGo to next message
Maven plugun 3.0.6 released and uploaded to Plugin Central. You can update it through Hudson Plugin Manager
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist [message #1724018 is a reply to message #1724011] Fri, 19 February 2016 21:09 Go to previous messageGo to next message
Hi Winston,
thanks for the release. I will test the new version on monday morning in my test enviroment and give you as soon as possible feedback.
I which you a nice weekend.
So long ...
Denis
Re: Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist [message #1724176 is a reply to message #1724018] Mon, 22 February 2016 06:54 Go to previous message
Hi Winston,
great news: It works !!!!
I test the new version on an windows client and made also regression checks on linux. All works without errors.
Thanks for the new version ...
Denis
Previous Topic:Hudson 3.3.3 -> Oracle Linux - rpm package has error => solved
Next Topic:Hudson 3.3.3 Oracle Linux rpm -> Service running, status wrong
Current Time: Tue Apr 16 23:19:04 GMT 2024
Powered by FUDForum. Page generated in 2.48059 seconds
