Transformation of UML models with stereotypes (profiles) [message #1723849] |
Thu, 18 February 2016 13:31 |
Supernova S. Messages: 5 Registered: January 2011 |
How is it possible to transform a UML model which has applied stereotypes from a profile, e.g., EAST-ADL ? How can stereotypes be read and accessed in model transformation code?
Basically, I am looking for an example transformation code (in QVTo or ATL) that transforms a Papyrus UML model ( to whatever) which has stereotypes.
Can anyone provide or point me to such an example?
[Updated on: Thu, 18 February 2016 13:59] Report message to a moderator
Re: Transformation of UML models with stereotypes (profiles) [message #1723857 is a reply to message #1723849] |
Thu, 18 February 2016 14:00 |
Camille Letavernier Messages: 952 Registered: February 2011 |
UML Elements have a #getStereotypeApplication method, returning instances of the required stereotypes. You can manipulate with two distinct approaches:
- Explicitly: you need to specify the profile URI in your transformation, then you can use oclAsType() to cast the stereotype application to your specific stereotype. Once this is done, you can access the stereotype properties directly
- With the generic API: using #getValue(Stereotype, Name) and #setValue(Stereotype, Name, Value)
modeltype uml "strict" uses 'http://www.eclipse.org/uml2/5.0.0/UML';
modeltype sysml "strict" uses 'http://www.eclipse.org/papyrus/0.7.0/SysML';
modeltype sysmlBlocks "strict" uses 'http://www.eclipse.org/papyrus/0.7.0/SysML/Blocks';
transformation StereotypesTransform(inout model : uml);
main() {
model.objectsOfType(Class).map blockToEncapsulated();
model.objectsOfType(Class).map blockToEncapsulatedGeneric();
mapping inout Class::blockToEncapsulated() when { /* Using the SysML API: modeltypes need to be declared for each sub-profile */
self.getAppliedStereotype("SysML::Blocks::Block") <> null
var blockStereotype : Stereotype := self.getAppliedStereotype("SysML::Blocks::Block");
var block : Block := self.getStereotypeApplication(blockStereotype).oclAsType(Block);
block.isEncapsulated := true;
mapping inout Class::blockToEncapsulatedGeneric() when { /* Using the UML Reflexive API: you don't need the modeltypes, but you're manipulating Strings and Objects... Very error-prone */
self.setValue(blockStereotype, "isEncapsulated", true);
var isEncapsulated : Boolean := self.getValue(blockStereotype, "isEncapsulated").oclAsType(Boolean);
Camille Letavernier
Re: Transformation of UML models with stereotypes (profiles) [message #1723858 is a reply to message #1723849] |
Thu, 18 February 2016 14:02 |
Ed Willink Messages: 7655 Registered: July 2009 |
It's not very exciting code but the following extract from
http://git.eclipse.org/c/ocl/org.eclipse.ocl.git/tree/examples/org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/qvto/UML2EcoreSynthesizer.qvto
accesses the Ecore::EDataType:instanceClassName stereotype field.
mapping inout Ecore::EClassifier::installInstanceClassName(in types :
Set(UML::Type), stereotypeName : String)
var stereotypedTypes : Set(UML::Type) :=
types->select(getAppliedStereotype(stereotypeName) <> null)->asSet();
var stereotypedType : UML::Type := stereotypedTypes->any(true);
-- var stereotypes : Set(UML::Stereotype) :=
createType.oldTypes.oclAsType(UML::DataType).getAppliedStereotype('Ecore::EDataType')->asSet();
-- log('stereotypedType', stereotypedType);
var instanceClassName : String :=
stereotypedType.getValue(stereotypedType.getAppliedStereotype(stereotypeName),
'instanceClassName').oclAsType(String);
-- log('instanceClassName', instanceClassName);
self.instanceClassName := instanceClassName;
-- result.defaultValue := instanceClassName;
Ed Willink
On 18/02/2016 13:31, Supernova S. wrote:
> ATL) that transforms a Papyrus UML model which has stereotypes.
FUDForum. Page generated in 0.02113 seconds
