Home » Eclipse Projects » Hudson » Hudson 3.3.3 -> Oracle Linux - rpm package has error => solved(oel distro-file hudson-3.3.3-1.1.noarch.rpm seems to be an package for suse)
icon14.gif  Hudson 3.3.3 -> Oracle Linux - rpm package has error => solved [message #1723822] Thu, 18 February 2016 09:32 Go to next message
Denis Schettl is currently offline Denis SchettlFriend
I have downloaded the file hudson-3.3.3-1.1.noarch.rpm from hudson-ci.org-website (checked twice: for oracle linux). After installation in my hudson-test-system (running oel 6.7 latest patch level) (via rpm -Uhv hudson-3.3.3-1.1.noarch.rpm) and starting hudson from command-line I get this error:
/etc/init.d/hudson: Zeile 52: /etc/rc.status: Datei oder Verzeichnis nicht gefunden
This meens that the file /etc/rc.status did not exist. I seached in the web and it seems to be that this file exist in suse-linux-systems.
Is it possible, that the suse-rpm-file is linked on the hudson-ci.org-web-site to the oracle-linux-download area?
Thanks for help ...
Denis
[Updated on: Fri, 19 February 2016 06:50]
Report message to a moderator
Re: Hudson 3.3.3 -> Oracle Linux - rpm package has error [message #1723898 is a reply to message #1723822] Fri, 19 February 2016 01:06 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
Looks like you are correct. We will fix the problem and upload new RPM as soon as possible.
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.3.3 -> Oracle Linux - rpm package has error [message #1723899 is a reply to message #1723898] Fri, 19 February 2016 01:14 Go to previous messageGo to next message
Correct RPM is uploaded now. Sorry for the inconvenience.
Winston Prakash
Eclipse Hudson team
icon14.gif  Re: Hudson 3.3.3 -> Oracle Linux - rpm package has error [message #1723927 is a reply to message #1723899] Fri, 19 February 2016 06:49 Go to previous message
Hi Winston,
I can confirm that the new provided rpm-file for oracle-linux now is installable without any error.
Thanks for your and the team work on Hudson !!!!
So long ...
Denis
Previous Topic:Hudson job that does not block
Next Topic:Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist => solved
Current Time: Tue Oct 27 02:14:00 GMT 2020
Powered by FUDForum. Page generated in 0.01555 seconds
