Home » Modeling » M2T (model-to-text transformation) » Use of workspace-external template for EGL run Config( Usage of template file (EGL) not in workspace)
Use of workspace-external template for EGL run Config [message #1723608] Tue, 16 February 2016 18:08 Go to next message
HanK CP is currently offline HanK CPFriend
Hi Community,
I want to configure a run-configuration for an EGL-template.
In detail, in this run-config, I want to refer to a template file (xxxx.egl) not contained in the workspace.
Somehow, this does not seem to be possible, or I am just too short-sighted to find a solution to it.
I would be thankful for any small mercies from You Wink
Re: Use of workspace-external template for EGL run Config [message #1724602 is a reply to message #1723608] Wed, 24 February 2016 20:47 Go to previous message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Importing your EGL template in the workspace through a linked file/folder would probably help [1]. For any further questions on Epsilon, I'd suggest using the Epsilon forum [2] instead.
Dimitris
[1] http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.user%2Ftasks%2Ftasks-45.htm
[2] https://www.eclipse.org/forums/index.php/f/22/
Previous Topic:Cannot Access SysML Sterotypes and their properties
Next Topic:I have the editor and the template. Now what?
Current Time: Thu Sep 29 03:21:06 GMT 2022
Powered by FUDForum. Page generated in 0.02759 seconds
