Home » Eclipse Projects » Sirius » How to access diagram from a tabbar extenstion
How to access diagram from a tabbar extenstion [message #1723483] Tue, 16 February 2016 00:15 Go to next message
Nikolay Manolov is currently offline Nikolay ManolovFriend
I was able to make a tabbar button In accordance with these instructions https://www.eclipse.org/sirius/doc/developer/extensions-provide_tabbar_extensions.html
I want this button to perform some kind of action. I have not decided exactly what ,but it will be related to the diagram and the semantic model. The problem I have is that I have no clue how to get to the diagram from the handler-class that is associated with the button.
This is what it looks like
public class ShowBaseHandler implements IHandler {
	public void addHandlerListener(IHandlerListener handlerListener) {
	public Object execute(ExecutionEvent event) throws ExecutionException {
		return null;
        ... other methods left out
Can I get the diagram via the *event* parameter or is there a way through the active editor/input?
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor().getEditorInput()
Nik
[Updated on: Tue, 16 February 2016 00:16]
Report message to a moderator
Re: How to access diagram from a tabbar extenstion [message #1724213 is a reply to message #1723483] Mon, 22 February 2016 10:27 Go to previous message
Florian Barbin is currently offline Florian BarbinFriend
Hi Nik,
you can retrieve the current diagram editor from the current active page:
currentPage.getActivePart()
if the active part is an instance of
org.eclipse.gmf.runtime.diagram.ui.parts.IDiagramWorkbenchPart, you can
get either the GMF Diagram or the Diagram edit part.
regards,
Florian
> @Override
> @Override
> return null;
> through the active editor/inpout?
> Cheers,
> Nik
Florian - Obeo
Previous Topic:Layers contribute to same container mapping (reuse/import)
Next Topic:Problems with self referencing objects
Current Time: Thu Feb 25 13:18:49 GMT 2021
Powered by FUDForum. Page generated in 0.01586 seconds
