Home » Eclipse Projects » Oomph » Product install fails; Could not find my feature
Product install fails; Could not find my feature [message #1723195] Fri, 12 February 2016 13:02 Go to next message
Fredrik Lindqvist is currently offline Fredrik LindqvistFriend
I've created an Oomph product model and just to verify that it works I've just stepped through the "New oomph product model" wizard, choosing simple product and accepting default values.
When I drag-and-drop the setup file to a running Eclipse Installer and try to install it, it fails:
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1455281349493
  ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: artificial_root 1.0.0.v1455281349493 requires 'my.product.feature.group 0.0.0' but it could not be found
Note that "my.product.feature.group" is the product model I have just created.
Setup file included.
setup log included.
  • Attachment: MyProduct.setup
    (Size: 1.39KB, Downloaded 181 times)
  • Attachment: setup.log
    (Size: 3.04KB, Downloaded 68 times)
Re: Product install fails; Could not find my feature [message #1723211 is a reply to message #1723195] Fri, 12 February 2016 13:50 Go to previous message
Fredrik,
Of course it doesn't create one that that just works. If you want to
see ones that work, you can look at all the ones in the existing product
catalogs. Just use Navigate -> Open Setup -> Parent Models -> Open
Catalog Index and from there you can look at what's in all the existing
catalogs.
Generally a product definition will require you to build a sensible p2
task with update sites and feature IDs...
> setup log included.
Previous Topic:Package and distribute installer + product/project model?
Next Topic:Oomph for automated builds
Current Time: Sat May 30 09:49:49 GMT 2020
Powered by FUDForum. Page generated in 0.01841 seconds
