Home » Modeling » TMF (Xtext) » Regarding Resource URI
Regarding Resource URI [message #1723135] Fri, 12 February 2016 05:14 Go to next message
pranay roy is currently offline pranay royFriend
Resource  Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
        XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
        resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
     [b]   Resource resource = resourceSet.createResource(URI.createURI("file:/example.mydsl"));[/b]
        InputStream in = new ByteArrayInputStream("plot abc".getBytes());
        resource.load(in, resourceSet.getLoadOptions());
        Model model = (Model) resource.getContents().get(0);
        System.out.println(model.getGreetings().getMeasure());
I am using this to execute standalone app and .This runs fine when I call using the main method.
However, I am trying to call the same "method" using a another web based project.
I get an exception on this line
I understand that file:/example.mydsl works (with main main method)as there it translates to correct URI .
How should it be packaged such that it searches the packaged jar and not a relative URI as above.
I also read
https://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F about platform: and file: and how it translates to correct URI. This does't seem to help.
probably I am missing a simple point. Please help
Re: Regarding Resource URI [message #1723136 is a reply to message #1723135] Fri, 12 February 2016 05:32 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Can you share the exception you get?
Maybe a uri.createUri("dummy.mydsl") fixes the problem
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Regarding Resource URI [message #1723137 is a reply to message #1723135] Fri, 12 February 2016 05:38 Go to previous messageGo to next message
And maybe a get resource (uri,true) is better than a createresource
Re: Regarding Resource URI [message #1723138 is a reply to message #1723137] Fri, 12 February 2016 06:17 Go to previous messageGo to next message
This is an exception referring to Lexer. But it triggers here -> resource.load(in, resourceSet.getLoadOptions()); I am using a spring boot project and have a get api calling the method above. Moreover, I have also added the xtext project as the dependency to my spring boot so I can call the method
at org.antlr.runtime.BufferedTokenStream.fetch(BufferedTokenStream.java:143) ~[antlr4-4.5.2-1.jar:?]
at org.antlr.runtime.BufferedTokenStream.sync(BufferedTokenStream.java:137) ~[antlr4-4.5.2-1.jar:?]
at org.antlr.runtime.BufferedTokenStream.fill(BufferedTokenStream.java:286) ~[antlr4-4.5.2-1.jar:?]
at org.antlr.runtime.BufferedTokenStream.toString(BufferedTokenStream.java:251) ~[antlr4-4.5.2-1.jar:?]
at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.parse(AbstractInternalAntlrParser.java:534) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:102) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.parse(AbstractAntlrParser.java:84) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:62) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.xtext.parser.AbstractParser.parse(AbstractParser.java:33) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:170) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:100) ~[org.eclipse.xtext-2.9.1.jar:?]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518) ~[org.eclipse.emf.ecore-2.11.1-v20150805-0538.jar:?]
at org.xtext.example.mydsl.Main.dsl(Main.java:46) ~[classes/:?]
at com.einsights.suggestions.controller.Controller.standAloneApp(Controller.java:111) ~[classes/:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_45]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_45]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_45]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:1.8.0_45]
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:222) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:814) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:737) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:969) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:860) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622) ~[tomcat-embed-core-8.0.30.jar:8.0.30]
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:845) ~[spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) ~[tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) ~[tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) ~[tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) ~[tomcat-embed-websocket-8.0.30.jar:8.0.30]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) ~[tomcat-embed-core-8.0.30.jar:8.0.30]
at org.springframework.boot.actuate.autoconfigure.EndpointWebMvcAutoConfiguration$ApplicationContextHeaderFilter.doFilterInternal(EndpointWebMvcAutoConfiguration.java:237) ~[spring-boot-actuator-1.3.2.RELEASE.jar:1.3.2.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365) ~[shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90) ~[shiro-core-1.2.4.jar:1.2.4]
at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83) ~[shiro-core-1.2.4.jar:1.2.4]
at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:383) ~[shiro-core-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362) ~[shiro-web-1.2.4.jar:1.2.4]
at org.springframework.boot.actuate.trace.WebRequestTraceFilter.doFilterInternal(WebRequestTraceFilter.java:111) ~[spring-boot-actuator-1.3.2.RELEASE.jar:1.3.2.RELEASE]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:87) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:77) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.boot.actuate.autoconfigure.MetricsFilter.doFilterInternal(MetricsFilter.java:103) ~[spring-boot-actuator-1.3.2.RELEASE.jar:1.3.2.RELEASE]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:521) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1096) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:674) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456) [tomcat-embed-core-8.0.30.jar:8.0.30]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_45]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_45]
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-embed-core-8.0.30.jar:8.0.30]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_45][/code]\
Re: Regarding Resource URI [message #1723139 is a reply to message #1723138] Fri, 12 February 2016 06:24 Go to previous messageGo to next message
I get the same exception when I use dummy
Re: Regarding Resource URI [message #1723140 is a reply to message #1723139] Fri, 12 February 2016 06:33 Go to previous messageGo to next message
the resource.load should be able to read properly from the steam.
maybe this is an encoding issue (the trace seems to missing what kind the exception is)
InputStream in = new ByteArrayInputStream("plot abc".getBytes(Charsets.UTF-8));
Re: Regarding Resource URI [message #1723141 is a reply to message #1723140] Fri, 12 February 2016 06:37 Go to previous messageGo to next message
btw why antlr 4.4 ?!? xtext ususally uses XtextTokenStream and antlr 3.2
[Updated on: Fri, 12 February 2016 06:47]
Report message to a moderator
Re: Regarding Resource URI [message #1723145 is a reply to message #1723141] Fri, 12 February 2016 06:52 Go to previous messageGo to next message
I am not sure why antlr.
About the exception it works perfectly when I use
Resource resource = resourceSet.createResource(URI.createURI("dummy.eindsl"));
or
and call using the main method.
However, when I call the same method from a spring boot app .I get the exception. I just invoke the method . I don't pass any input
@RequestMapping(value="/runStandAlone",method =RequestMethod.GET)
    public void  standAloneApp() throws IOException {
    MainClass.dsl();
the content of dsl method is what I sent before and works Ok when I use the MainClass to execute.
There seems to be some issue wrt to the URI. Sad
Re: Regarding Resource URI [message #1723152 is a reply to message #1723145] Fri, 12 February 2016 08:00 Go to previous message
Hi Christian,
Thank you for pointing out about antlr . It came from dependency from another module. I removed it and it works now. ! Thanks much Smile.....!
Previous Topic:Where put dependecy in new maven/gradle project build ?
Next Topic:Problem using xreference
Current Time: Sat Dec 03 23:40:10 GMT 2022
Powered by FUDForum. Page generated in 0.02420 seconds
