Home » Modeling » TMF (Xtext) » Best way to check if an inferred type is part of the model
Best way to check if an inferred type is part of the model [message #1722705] Mon, 08 February 2016 12:28 Go to next message
herve giraud is currently offline herve giraudFriend
I have a DSL that looks like this:
Entity:
  'entity' name=ValidID '{'
          properties+=Property*
Property:
  type=JvmTypeReference name=ValidID;
Message:
  'message' name=ValidID '{'
and I subclass AbstractModelInferrer so any Entity can be seen as a JVM type.
But now, I need to know if the properties of a message are from the JVM or are part of the DSL.
What is the best way to get that information ?
Herve
Re: Best way to check if an inferred type is part of the model [message #1722707 is a reply to message #1722705] Mon, 08 February 2016 12:50 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
did you have a look at jvmmodelassociations? it should give you a sourceelement is the jvmelement is derived
Twitter : @chrdietrich
Re: Best way to check if an inferred type is part of the model [message #1722765 is a reply to message #1722707] Mon, 08 February 2016 22:39 Go to previous message
Thanks, I will try
Previous Topic:Xcore with xtext-maven-plugin: unmapped ecore model path
Next Topic:Handling XBase references to overloaded signatures outside of XBlockExpressions
Current Time: Tue Apr 16 22:38:28 GMT 2024
Powered by FUDForum. Page generated in 7.81991 seconds
