Auto size for class rectangle [message #1722649] |
Sun, 07 February 2016 21:19 |
Lutz Wrage Messages: 181 Registered: July 2009 |
I have class diagrams where I want to show only the class name. I have hidden the compartments for attributes, operations, and nested classifiers. When I now select a class symbol and use Format -> Autosize the width of the rectangle is adjusted such that the class name fits. However, the height of the rectangle for the class does not change. I had expected that it shrinks to the size of the name compartment.
If I manually reduce the height and autosize again the rectangle height goes back to the much too big value. It seems that the height computation ignores the fact that the compartments are hidden.
Is this a bug or is there a way to make this work?
FUDForum. Page generated in 0.01739 seconds
