Home » Modeling » Papyrus » UML Profiles and SysML FlowPorts(About Using the Flowports of SysML)
UML Profiles and SysML FlowPorts [message #1722640] Sun, 07 February 2016 18:03 Go to next message
Muhammad Kashif is currently offline Muhammad KashifFriend
Member
I am developing a UML profile, I want to use SysML's Flowports and there is n metaclass of "flowports" because in UML there is no such thing as flowports but ports only (without direction).
Is there any way that I can use flowports at profile level. The main purpose to use flow ports is because of their direction..
Please help me out in this problem..
Thanks in advance
Re: UML Profiles and SysML FlowPorts [message #1722677 is a reply to message #1722640] Mon, 08 February 2016 09:01 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Profiles only support a subset of UML. Basically, everything that is in the Papyrus Profile Diagram palette. Anything else won't be supported (Or might be accidentally, partially supported...)
A Profile is similar to a Metamodel, in this sense that it only supports few, core concepts (Stereotype, Properties, Associations, Generalization and various data types, etc.). If you need more advanced concepts from UML or SysML, you're probably misunderstanding the notion of Profiles. Maybe a UML Library (Model) would be more fit for your usage? Or even a mix of a Profile and a Library
Camille
Camille Letavernier
Re: UML Profiles and SysML FlowPorts [message #1722713 is a reply to message #1722677] Mon, 08 February 2016 14:06 Go to previous message
Member
Thanks for the response..
So there is no way to use flowports at profile level..
Actually I want to provide flowports in profile, Is it possibe that I give only port and the in model flowport stereotype can be applied to that port to make it work like a flowport..?
Or any other alternative??
Thanks in advance
Previous Topic:Change font for association ends
Next Topic:Any type of Feature is allowed for Slots
Current Time: Wed Mar 03 15:37:16 GMT 2021
Powered by FUDForum. Page generated in 0.02628 seconds
