Jubula 8.2.2 released [message #1722490] |
Fri, 05 February 2016 09:39 |
Alexandra Schladebeck Messages: 1613 Registered: July 2009 |
Hello!
We have released an official standalone release of Jubula today: 8.2.2
The highlights are:
- The completeness check has been moved to a background job, resulting in less waiting time for save actions.
- You can now copy and paste Test Cases, Test Suites, Test Steps and Event Handlers within editors.
- You can set the Object Mapping Profile for single elements in the Object Mapping Editor, for example, to ensure that a specific component will only be searched for based on its given name.
- There are new Test Steps (and unbound modules, and client API actions) to invoke Java methods on an application, or on a component within an application.
- You can now add multi-line comments in editors so that larger groups of items can be commented in the test.
- There are new actions in the dbtool to delete all test result summaries for a project or time span, and to delete all test result details for a project or time span.
- There is a new log view in the test reporting perspective, which lets users see std_out and std_err messages produced when the execute external command action is used in a test
- We have cleaned up some no-longer used / supported features such as metrics, multi-language capability, the .NET and WinApps toolkits and the external Chronon support.
- There is an Oomph setup for Jubula
- The ITE now runs on Java 8
You can download the version from: http://testing.bredex.de/jubula-download-page.html
Happy testing!
Alex and the Jubula team
FUDForum. Page generated in 0.04249 seconds
