Home » Modeling » TMF (Xtext) » [solved] xtend helper to escapeHTML(string)(is there a helper in XTEND to convert a string to an HTML-one?)
[solved] xtend helper to escapeHTML(string) [message #1722269] Wed, 03 February 2016 16:39 Go to next message
Uli Merkel is currently offline Uli MerkelFriend
Working on that "Survey" example.
If the user enters some special characters as a title string,
they may have to be escaped before I can write it into my HTML file.
Is there some helper to do this in the generator?
[Updated on: Wed, 03 February 2016 17:25]
Report message to a moderator
Re: xtend helper to escapeHTML(string) [message #1722271 is a reply to message #1722269] Wed, 03 February 2016 16:44 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi we use commons langs StringEdcapeUtils for that
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: xtend helper to escapeHTML(string) [message #1722273 is a reply to message #1722271] Wed, 03 February 2016 17:08 Go to previous messageGo to next message
Tried your hint with some example from the web:
import org.apache.commons.lang.StringEscapeUtils;
String results = StringEscapeUtils.escapeHtml("gjhkj>-");
when I try to enter in my SurveyGenerator.extend:
I get an error that this can not be resolved to a type.
and therefore the following code fails as well:
def test1 () {
val escaped = StringEscapeUtils.escapeHtml("abc");
Is there something I overlooked?
TIA, Uli
Re: xtend helper to escapeHTML(string) [message #1722274 is a reply to message #1722273] Wed, 03 February 2016 17:11 Go to previous messageGo to next message
Die you add a required bundle or a import package to the manifest
Re: xtend helper to escapeHTML(string) [message #1722275 is a reply to message #1722274] Wed, 03 February 2016 17:24 Go to previous message
Hi Christian,
thanks for this other hint.
It works now (just overlooked to add it to the dependecies)
Previous Topic:Understand Build
Next Topic:Accessing properties... the right way!
Current Time: Wed Nov 30 17:38:07 GMT 2022
Powered by FUDForum. Page generated in 0.02541 seconds
