Re: UML Profile and SMD [message #1722185 is a reply to message #1722178] |
Wed, 03 February 2016 09:38 |
Hi Muhammad,
It is by definition of the UML specification not possible to apply the same stereotype several times to the same element. So Papyrus will not let you apply several time S1 on the same state machine.
You can apply S1 on different state machines, but only one application per state machine.
Rémi
Extract of the norm:
Quote:A non-required Extension (isRequired = false) means that an instance of this Stereotype may be linked to an instance of an extended metaclass at will, and also later deleted at will; however, there is no requirement that each instance of a metaclass be stereotyped. However the same stereotype (or its subtypes) can never be applied twice to the same element. An instance of a Stereotype is deleted when either the instance of the extended metaclass is deleted, or when the Profile defining the stereotype is removed from the appliedProfiles of the Package.
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03926 seconds
