Re: problem in java service project "Family" [message #1722219 is a reply to message #1722114] |
Wed, 03 February 2016 13:23 |
Hi Santiago,
Le 02/02/2016 23:07, Santiago Jacome a écrit :
> I implemented the project of "Family", but I have a problem running Java services, the parameter (Person person) is not recognized in --> public String getPersons(Person person) .
> Please if someone could explain why the error occurs.
> The error is displayed which states as follows:
> (sorry for my English)
Which version of Sirius do you use ?
Note that with Sirius 3 you can define Java services and then try them
directly in your current development environment, you do not need
anymore to launch another runtime just to test your services.
With older version you need to launch a runtime.
Maxime - Obeo
Maxime Porhel - Obeo
Re: problem in java service project "Family" [message #1722251 is a reply to message #1722220] |
Wed, 03 February 2016 15:31 |
Le 03/02/2016 14:35, Santiago Jacome a écrit :
> Hi Maxime,
> I installed and use --> Obeo Designer Community (Version 8.1.1)
Obeo Designer Community Edition contains Sirius 3.1.1.
I have just tested to create the same kind of table with column labels
computed from by a service with the sample basic family metamodel, I do
not get the same error than you.
I noticed that your projects are name org.clipse.sirius.xxx
Did you rename them from org.eclipse.sirius.. or created them from
scratch to follow the tutorial ?
Did you do the same rename with you metamodel ? Or did you install the
sample provided by Sirius / Obeo Designer ?
> Regards,
> Santiago
Maxime - Obeo
FUDForum. Page generated in 0.05319 seconds
