Home » Modeling » Graphiti » can not save connection Feature
can not save connection Feature [message #1721860] Mon, 01 February 2016 06:24 Go to next message
Kailas Patil is currently offline Kailas PatilFriend
I create my new EMF model to save pictorial element, and connection, the pictorial element is save but connection is not save
this is my code for connection feature.
public class CreateConditionalFlowFeature extends AbstractCreateConnectionFeature {
String type;
public CreateConditionalFlowFeature(IFeatureProvider fp, String name, String description, String type) {
super(fp, name, description);
this.type = type;
public boolean canCreate(ICreateConnectionContext context) {
ComplianceModel source = getComplianceModel(context.getSourceAnchor());
ComplianceModel target = getComplianceModel(context.getTargetAnchor());
if (source == null || target == null) {
return false;
ActivityInfo sourceActivityInfo = (ActivityInfo) source.getActivityInfo();
ActivityInfo targetActivityInfo = (ActivityInfo) target.getActivityInfo();
int sourceOutboundLimit = sourceActivityInfo.getOutboundConnectionLimit();
int targetInboundLimit = targetActivityInfo.getInboundConnectionLimit();
if (source != null && target != null && source != target) {
if (sourceOutboundLimit == -1 && targetInboundLimit == -1) {
return true;
} else if (sourceOutboundLimit == -1 && targetInboundLimit == 0) {
return false;
} else if (sourceOutboundLimit == 0) {
return false;
return false;
public String getCreateImageId() {
return ImageProvider.CONDITIONALFLOW;
public boolean canStartConnection(ICreateConnectionContext context) {
if (source != null) {
if (sourceActivityInfo.getOutboundConnectionLimit() == 0) {
return false;
return true;
return false;
public Connection create(ICreateConnectionContext context) {
Connection newConnection = null;
if (source != null && target != null) {
ComplianceLink eReference = createLink(source, target);
AddConnectionContext addContext = new AddConnectionContext(context.getSourceAnchor(),
addContext.setNewObject(eReference);
newConnection = (Connection) getFeatureProvider().addIfPossible(addContext);
return newConnection;
private ComplianceModel getComplianceModel(Anchor anchor) {
if (anchor != null) {
Object obj = getBusinessObjectForPictogramElement(anchor.getParent());
if (obj instanceof ComplianceModel) {
return (ComplianceModel) obj;
return null;
private ComplianceLink createLink(ComplianceModel source, ComplianceModel target) {
ComplianceLink link = ComplianceWorkflowModelFactory.eINSTANCE.createComplianceLink();
link.setName("Conditional"); //$NON-NLS-1$
link.setSource(source);
link.setTarget(target);
link.setType("ConditionalFlow");
//source.setEStructuralFeatures().add(link);
return link;
so how could i save that connection,
[Updated on: Mon, 01 February 2016 06:25]
Report message to a moderator
Re: can not save connection Feature [message #1721907 is a reply to message #1721860] Mon, 01 February 2016 16:00 Go to previous message
Michael Wenz is currently offline Michael WenzFriend
Kailas,
saving the connection instance can be done indirectly by adding it to the diagram and so to an EMF resource and saving the editor holding the resource. I see that you create the connection instance by delegating to the add feature, which should be fine. You should make sure that the new connection is added as child to your diagram inside the add feature.
HTH,
Michael
Previous Topic:Move diagram along with text
Next Topic:Integration of the KIELER Framework
Current Time: Sun Jan 17 23:28:58 GMT 2021
Powered by FUDForum. Page generated in 0.02193 seconds
