Home » Newcomers » Newcomers » Mars installation problem(Java keeps running when eclipse is started )
Mars installation problem [message #1721796] Sun, 31 January 2016 00:04 Go to next message
Gary Roach is currently offline Gary RoachFriend
I installed Mars.1 from the tar file, I unzipped the file and transfered the eclipse directory to the /opt directory, I set up the desktop icon the start /opt/eclipse/eclipse. This is a new installation. No active projects and no added plugins. Java keeps running and takes up about 30% of my cpu time. All of the preference windows are frozen. They open with the initial information but can not be changed. One can switch to another sub-menu but the screen will never change. I included the error log output at the end of this missive. I hope it helps.
System
Debian Linux stretch (testing)
KDE Desktop
4 processor 2.6 GHz cpu
12 GB memory
Java version:
root@supercrunch:/usr/bin# java -version
java version "1.7.0_91"
OpenJDK Runtime Environment (IcedTea 2.6.3) (7u91-2.6.3-1)
OpenJDK 64-Bit Server VM (build 24.91-b01, mixed mode)
I hop some one knows what's going on here. Se error log below
Gary R
!ENTRY org.eclipse.equinox.p2.metadata 1 0 2016-01-30 11:09:20.813
!MESSAGE No translation source unavailable. Default language will be used.
!ENTRY org.eclipse.equinox.event 4 0 2016-01-30 11:12:04.733
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/SET] {NewValue=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveImpl@5dd900b (elementId: org.python.pydev.ui.PythonPerspective.<PyDev>, tags: [persp.actionSet:org.eclipse.mylyn.doc.actionSet, persp.actionSet:org.eclipse.mylyn.tasks.ui.navigation, persp.actionSet:org.eclipse.ui.cheatsheets.actionSet, persp.actionSet:org.eclipse.search.searchActionSet, persp.actionSet:org.eclipse.ui.edit.text.actionSet.annotationNavigation, persp.actionSet:org.eclipse.ui.edit.text.actionSet.navigation, persp.actionSet:org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo, persp.actionSet:org.eclipse.ui.externaltools.ExternalToolsSet, persp.actionSet:org.eclipse.ui.actionSet.keyBindings, persp.actionSet:org.eclipse.ui.actionSet.openFiles, persp.actionSet:org.eclipse.wb.core.ui.actionset, persp.actionSet:com.zeroturnaround.eclipse.optimizer.plugin.actionSet, persp.newWizSC:org.python.pydev.ui.wizards.project.PythonProjectWizard, persp.newWizSC:org.python.pydev.ui.wizards.files.PythonSourceFolderWizard, persp.newWizSC:org.python.pydev.ui.wizards.files.PythonPackageWizard, persp.newWizSC:org.python.pydev.ui.wizards.files.PythonModuleWizard, persp.newWizSC:org.eclipse.ui.wizards.new.folder, persp.newWizSC:org.eclipse.ui.wizards.new.file, persp.newWizSC:org.eclipse.ui.editors.wizards.UntitledTextFileWizard, persp.viewSC:org.python.pydev.views.PyCodeCoverageView, persp.viewSC:org.python.pydev.navigator.view, persp.viewSC:org.python.pydev.debug.pyunit.pyUnitView, persp.viewSC:org.eclipse.search.ui.views.SearchView, persp.viewSC:org.eclipse.ui.console.ConsoleView, persp.viewSC:org.eclipse.ui.views.ContentOutline, persp.viewSC:org.eclipse.ui.views.ProblemView, persp.viewSC:org.eclipse.pde.runtime.LogView, persp.viewSC:org.eclipse.ui.views.TaskList, persp.actionSet:org.eclipse.debug.ui.launchActionSet, persp.actionSet:org.eclipse.ui.NavigateActionSet, persp.actionSet:com.python.pydev.navigate.actionSet, persp.showIn:org.eclipse.ui.views.ResourceNavigator, persp.showIn:org.python.pydev.navigator.view, persp.showIn:org.eclipse.ui.views.ContentOutline], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer@11a1c9d5, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: <PyDev>, iconURI: platform:/plugin/org.python.pydev/icons/python_16x16.png, tooltip: null, context: PerspectiveImpl (org.python.pydev.ui.PythonPerspective) Context, variables: []), ChangedElement=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl@14e6ab23 (elementId: org.eclipse.ui.ide.perspectivestack, tags: [], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer@5bc176f, toBeRendered: true, onTop: false, visible: true, containerData: 7500, accessibilityPhrase: null), EventType=SET, AttName=selectedElement, OldValue=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveImpl@3abc6623 (elementId: org.eclipse.ui.resourcePerspective, tags: [persp.actionSet:org.eclipse.mylyn.doc.actionSet, persp.actionSet:org.eclipse.mylyn.tasks.ui.navigation, persp.actionSet:org.eclipse.ui.cheatsheets.actionSet, persp.actionSet:org.eclipse.search.searchActionSet, persp.actionSet:org.eclipse.ui.edit.text.actionSet.annotationNavigation, persp.actionSet:org.eclipse.ui.edit.text.actionSet.navigation, persp.actionSet:org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo, persp.actionSet:org.eclipse.ui.externaltools.ExternalToolsSet, persp.actionSet:org.eclipse.ui.actionSet.keyBindings, persp.actionSet:org.eclipse.ui.actionSet.openFiles, persp.actionSet:org.eclipse.wb.core.ui.actionset, persp.actionSet:com.zeroturnaround.eclipse.optimizer.plugin.actionSet, persp.newWizSC:org.eclipse.ui.wizards.new.folder, persp.newWizSC:org.eclipse.ui.wizards.new.file, persp.viewSC:org.eclipse.ui.navigator.ProjectExplorer, persp.viewSC:org.eclipse.ui.views.
BookmarkView, persp.viewSC:org.eclipse.ui.views.ContentOutline, persp.viewSC:org.eclipse.ui.views.PropertySheet, persp.viewSC:org.eclipse.ui.views.ProblemView, persp.viewSC:org.eclipse.ui.views.ProgressView, persp.viewSC:org.eclipse.ui.views.TaskList, persp.actionSet:org.eclipse.ui.NavigateActionSet, persp.viewSC:org.eclipse.ant.ui.views.AntView, persp.showIn:org.eclipse.egit.ui.RepositoriesView, persp.perspSC:org.eclipse.jdt.ui.JavaPerspective, persp.perspSC:org.eclipse.jdt.ui.JavaBrowsingPerspective, persp.viewSC:org.eclipse.mylyn.tasks.ui.views.tasks, persp.newWizSC:org.eclipse.mylyn.tasks.ui.wizards.new.repository.task, persp.perspSC:org.eclipse.team.ui.TeamSynchronizingPerspective, persp.showIn:org.eclipse.team.ui.GenericHistoryView, persp.newWizSC:org.eclipse.ui.editors.wizards.UntitledTextFileWizard, persp.showIn:org.eclipse.ui.navigator.ProjectExplorer, persp.viewSC:org.eclipse.pde.runtime.LogView, persp.perspSC:org.eclipse.wst.jsdt.ui.JavaPerspective, persp.perspSC:org.eclipse.wst.xml.ui.perspective], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer@11a1c9d5, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: Resource, iconURI: platform:/plugin/org.eclipse.ui.ide.application/$nl$/icons/full/eview16/resource_persp.png, tooltip: null, context: PerspectiveImpl (org.eclipse.ui.resourcePerspective) Context, variables: []), Widget=Composite {}} to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@162980e8
!STACK 0
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showElementRecursive(LazyStackRenderer.java:238)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showElementRecursive(LazyStackRenderer.java:284)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showElementRecursive(LazyStackRenderer.java:290)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showTab(LazyStackRenderer.java:162)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:88)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4633)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$12.widgetSelected(PerspectiveSwitcher.java:590)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1329)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard.openDialog(SetupWizard.java:532)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard$Updater.openDialog(SetupWizard.java:1299)
at org.eclipse.oomph.setup.presentation.handlers.PerformHandler.run(PerformHandler.java:45)
at org.eclipse.oomph.setup.presentation.handlers.AbstractDropdownItemHandler.execute(AbstractDropdownItemHandler.java:50)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Re: Mars installation problem [message #1721826 is a reply to message #1721796] Sun, 31 January 2016 17:45 Go to previous message
Tauno Voipio is currently offline Tauno VoipioFriend
1. Please do not run Eclipse as root user. Install it for a regular user instead.
2. There has been a null pointer issue with the KDE GTK2 oxygen-gtk theme. If there is an alternative theme available (my Kubuntu has Raleigh), change it from the KDE control panel:
System Settings -> Application Appearance -> GTK
Tauno Voipio
Previous Topic:Eclipse appends local path when launching URLs
Next Topic:Migrating Old RCP Project
Current Time: Thu Oct 17 23:12:44 GMT 2019
Powered by FUDForum. Page generated in 0.02797 seconds
