Home » Modeling » TMF (Xtext) » using xtend or xpand for code generation
using xtend or xpand for code generation [message #1721735] Fri, 29 January 2016 15:03 Go to next message
AYMEN SALMAN is currently offline AYMEN SALMANFriend
Am already a biginner in the eclipse and xtext
Kindly am already in the middle of a project to develop a high level DSL language, where this language will be used by the user, and the output after compiling this DSL is to to generate a C language code.
That mean I have to develop a code generator that will convert the compiled AST into a C language code. That beside I have already build the dsl UI and commands library and the compiler using xtext and emf models.
And now am wondering which one I should use to build my C language generator, xpand or xtend and why?
Appreciate your kind help and support
Aymen
Re: using xtend or xpand for code generation [message #1721738 is a reply to message #1721735] Fri, 29 January 2016 15:15 Go to previous messageGo to next message
Axel Guckelsberger is currently offline Axel GuckelsbergerFriend
you should look at Xtend. Xpand is obsolete and Xtend is far superior.
Start here:
https://www.eclipse.org/xtend/
HTH,
Axel
Am 29.01.2016 um 16:03 schrieb AYMEN SALMAN:
> Hi
> models.
> Thanks
> Aymen
Re: using xtend or xpand for code generation [message #1721753 is a reply to message #1721738] Fri, 29 January 2016 19:20 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i would use xtend as well
- is statically compiled and thus faster if done correct
- i more actively developed
- is supported better by the default generator infrastructure (in eclipse builder, standalone maven/gradle etc)
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: using xtend or xpand for code generation [message #1721766 is a reply to message #1721738] Fri, 29 January 2016 23:57 Go to previous message
Thanks for your advice, and I will try using xtend and see how it will goes with me.
[Updated on: Fri, 29 January 2016 23:59]
Report message to a moderator
Previous Topic:Linking of duplicate objects in Xtext
Next Topic:Xcore with xtext-maven-plugin: unmapped paths
Current Time: Tue Nov 29 11:47:03 GMT 2022
Powered by FUDForum. Page generated in 0.02096 seconds
