Home » Eclipse Projects » Oomph » Assign project streams to product versions
Assign project streams to product versions [message #1721700] Fri, 29 January 2016 10:05 Go to next message
Oliver Libutzki is currently offline Oliver LibutzkiFriend
Member
is there a way to define which project streams are compatible with product versions.
Background: We use Xtext to provide some DSLs which are part of our Product. Everytime we have changes in the DSLs we provide a new Product version.
Each stream of our project is pinned to a specific version of the Product in order to ensure the DSL compatibility.
Is there a way to configure the relationship from the Project Stream to the Product version?
It would be great if the installer just provides project streams which are compatible with the chosen Product version.
Thanks for your answer!
Kind regards
Oliver
Re: Assign project streams to product versions [message #1721706 is a reply to message #1721700] Fri, 29 January 2016 10:21 Go to previous messageGo to next message
Oliver,
Comments below.
On 29.01.2016 11:05, Oliver Libutzki wrote:
> product versions.
No.
> Product version.
I see.
I wonder if a different approach wouldn't work okay... I.e., focus on
defining your project stream so that it can work with the Platform
Product, which is basically an Eclipse IDE with nothing specific
installed. Then your project definition itself can ensure that it
spells out all the specific things it wants installed into a bare bones
IDE. At least with your Xtext example, that should work quite well
because the latest Xtext can install into Neon, Mars, or other older
versions of the IDE...
> Kind regards
> Oliver
Ed Merks
Re: Assign project streams to product versions [message #1721998 is a reply to message #1721706] Tue, 02 February 2016 08:06 Go to previous message
Member
Ed Merks wrote on Fri, 29 January 2016 05:21
That's a great idea... thanks, Ed.
Previous Topic:Default value for unsigned content?
Next Topic:command line
Current Time: Mon Jan 25 18:39:42 GMT 2021
Powered by FUDForum. Page generated in 0.01571 seconds
