Home » Eclipse Projects » e(fx)clipse » Native launcher for windows build (maven-tycho + ant) is not working for e4 OSGI application(Need some detailed information on build in windows environment)
Native launcher for windows build (maven-tycho + ant) is not working for e4 OSGI application [message #1721540] |
Thu, 28 January 2016 08:33 |
Milankumar Ardeshana Messages: 27 Registered: August 2015 |
Hi all,
I am facing some problems in generating native(win) launcher for e4 efxclipse.
My configurations are as follows :
win 7,
e(fx)clipse - IDE - Basic 2.1.0.201508240705 org.eclipse.fx.ide.basic.feature.feature.group
target definition file:
<location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="slicer" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.fx.target.feature.feature.group" version="2.0.0.201506240602"/>
<repository location="http://download.eclipse.org/efxclipse/runtime-released/2.0.0/site/"/>
</location>
Steps i am following are as below :
My application getting run successfully from eclipse.
When i run my maven tycho build from cmd : "mvn clean install" its successfully getting finished.
Then when i try to run java -jar plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar -config configuration
I am getting logs in configuration directory as below.
!SESSION 2016-01-28 12:59:00.953 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_65
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -config configuration
Command-line arguments: -config configuration
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-28 12:59:01.767
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.log4j.Log4JLoggerFactory. The reference is: Reference[name = registerAppender, interface = org.apache.log4j.Appender, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerAppender, unbind = unregisterAppender, updated = null]
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-28 12:59:01.773
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.app 4 0 2016-01-28 12:59:01.781
!MESSAGE javafx/application/Application
!STACK 0
java.lang.NoClassDefFoundError: javafx/application/Application
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:327)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:402)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at org.eclipse.fx.ui.workbench.fx.E4Application.getJfxApplicationClass(E4Application.java:322)
at org.eclipse.fx.ui.workbench.fx.E4Application.launchE4JavaFxApplication(E4Application.java:307)
at org.eclipse.fx.ui.workbench.fx.E4Application.start(E4Application.java:111)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
Caused by: java.lang.ClassNotFoundException: javafx.application.Application cannot be found by org.eclipse.fx.ui.workbench.fx_2.2.0.201601272351
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
... 20 more
and my config.ini is as below.
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Thu Jan 28 12:42:44 IST 2016
eclipse.p2.profile=DefaultProfile
osgi.framework=file\:plugins/org.eclipse.osgi_3.10.101.v20150820-1432.jar
equinox.use.ds=true
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.1.100.v20150423-1455.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=com.mil.trial.app.product
osgi.splashPath=platform\:/base/plugins/com.mil.trial.app
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.compatibility.state_1.0.100.v20150402-1551.jar
osgi.bundles.defaultStartLevel=4
eclipse.p2.data.area=@config.dir/../p2
eclipse.application=org.eclipse.fx.ui.workbench.fx.application
Then i tried to build my ant build as JavaFX Packager is mandatory for native launcher.
I have got some errors.
So, I installed Wix and Inno setup 5 (5.5.6) as they were required for win environment.
Then again i tried to build ant.
It got successful.
So its having installer and .msi in deploy/bundle directory in releng project.
So when i execute installer it starts copying all data to C:\Users\user\AppData\Local\trial\
and when it finished it also run my trial.exe.
But no UI came up.
Then i found logs in C:\Users\user\AppData\Local\trial\app\workspace\.metadata\ .log as below without any exception.
!SESSION 2016-01-28 13:11:05.623 --------------x---------------------------------
java.version=1.8.0_60
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-28 13:11:06.601
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-28 13:11:06.603
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-28 13:11:06.959
!MESSAGE Could not bind a reference of component com.mil.trial.app.themes.default. The reference is: Reference[name = Stylesheet, interface = org.eclipse.fx.ui.services.theme.Stylesheet, policy = dynamic, cardinality = 0..n, target = null, bind = registerStylesheet, unbind = unregisterStylesheet]
My C:\Users\user\AppData\Local\trial\app folder also contains eclipse.ini and trial.cfg as below
elcipse.ini
-nosplash
-vmargs
-Dorg.osgi.framework.bundle.parent=ext
trial.cfg[Application]
app.name=trial
app.mainjar=plugins\org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
app.version=1.0
app.preferences.id=fxApplication
app.mainclass=org/eclipse/equinox/launcher/Main
app.classpath=
app.runtime=$APPDIR\runtime
app.identifier=fxApplication
[JVMOptions]
[JVMUserOptions]
[ArgOptions]
Is there anything wrong i am doing building steps?
Is there any way to verify build after tycho build has generated product?
Thanks in advance !
-Milan
Re: Native launcher for windows build (maven-tycho + ant) is not working for e4 OSGI application [message #1721869 is a reply to message #1721540] |
Mon, 01 February 2016 08:29 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
On 28.01.16 09:34, Milankumar Ardeshana wrote:
> Hi all,
> efxclipse.
> My configurations are as follows : win 7, e(fx)clipse - IDE - Basic
> <repository
> </location>
> configuration
> java.vendor=Oracle Corporation
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> at
> at
> at
> at
> ... 20 more
> equinox.use.ds=true
if you launch with java -jar you need to pass the
> https://docs.oracle.com/javafx/2/deployment/packager.htm is mandatory
> win environment.
> It got successful. So its having installer and .msi in deploy/bundle
> But no UI came up.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
These logs are ok and a "bug" in equinox ds so I have indication what is
wrong.
Tom
Current Time: Fri Apr 19 10:23:49 GMT 2024
Powered by FUDForum. Page generated in 0.02331 seconds
