Re: Using EMF Compare to Compare models [message #1721588 is a reply to message #1720948] |
Thu, 28 January 2016 14:03 |
Hi Virajitha,
you are comparing a copy of one Papyrus model with another, both residing in the workspace, right? So no Git repo involved, right?
With which files do you start the comparison? Have you tried starting the comparison for the uml-file or the notation-file instead of selecting the Papyrus "OneFile" node? Because this node is adapted to the di-file, thus by starting the comparison from the Papyrus OneFile node, you may eventually end up comparing the two di-files, which usually are empty.
Best wishes,
Philip
Philip Langer
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: Using EMF Compare to Compare models [message #1721740 is a reply to message #1721668] |
Fri, 29 January 2016 15:42 |
Hi Virajitha,
Could you ensure you have the "org.eclipse.emf.compare.diagram.papyrus" plugin installed ? (check that through "Help > About Eclipse". In there, click the "installation details" button, go to the "plugins" tab and use the filter to see if that plugin is there). If it is not installed, please install it from your eclipse release's repository (through Help > install new software, and select the eclipse repository from there).
If it is installed, could you raise a bugzilla here and attach your models there so that we can try and reproduce?
Laurent Goubet
Obeo
Re: Using EMF Compare to Compare models [message #1722221 is a reply to message #1721855] |
Wed, 03 February 2016 13:37 |
The plugin I am talking about should have been installed along with the one you're mentionning here. Could you try re-installing one of the latest EMF Compare (such as our latest milestone of 3.2.0 from this update site), making sure you select the "Model comparison (EMF Compare) - Papyrus support" feature when installing?
If it doesn't work, please raise a bugzilla with sample models with which we can reproduce the issue.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.04900 seconds
