Home » Eclipse Projects » P2 » Bundling JRE in a feature
Bundling JRE in a feature [message #1720946] Fri, 22 January 2016 05:59 Go to next message
Michal Kleczek is currently offline Michal KleczekFriend
Member
I've followed the instructions https://codeiseasy.wordpress.com/2012/07/31/including-a-jre-in-a-tycho-build/
to bundle JRE in a feature (not as a root file).
All works except file permissions in JRE are not retained during build on Mac.
As a workaround advised here:
https://dev.eclipse.org/mhonarc/lists/tycho-user/msg04632.html
I'm trying to use chmod touchpoint action to add execute bit to binaries inside JRE.
The problem is that I have no clue how to pass the location of a file to the chmod action. I've tried both native and eclipse action, passed @artifact and ${artifact.location} but none seems to be working.
Does anybody have any advice how to handle that?
[Updated on: Fri, 22 January 2016 06:00]
Report message to a moderator
Re: Bundling JRE in a feature [message #1721287 is a reply to message #1720946] Tue, 26 January 2016 11:00 Go to previous messageGo to next message
Member
Since it looks like nobody can answer this I'm going to share my solution.
What is working in setJvm and chmod touchpoint actions is ${installFolder} variable substitution.
So the path should be: ${installFolder}/features/featureid_featureversion/....
Now the problem is that $version$ substitution is not working as advertised. What I had to do is to use maven-resources-plugin to process p2.inf file with the following content (shown for Mac OS X):
instructions.configure=org.eclipse.equinox.p2.touchpoint.eclipse.setJvm(jvm:${installFolder}/features/[plarform_specific_jre_feature_id]_${qualifiedVersion}/jre/lib/jli/libjli.dylib);
instructions.install=org.eclipse.equinox.p2.touchpoint.eclipse.chmod(targetDir:${installFolder}/features/[plarform_specific_jre_feature_id]_${qualifiedVersion}/jre/lib,targetFile:jspawnhelper,permissions:755);
instructions.unconfigure=org.eclipse.equinox.p2.touchpoint.eclipse.setJvm(jvm:null);
Note setting jspawnhelper as executable - without that ProcessBuilder throws exception when trying to execute external process from Java program.
Hope that helps someone.
Re: Bundling JRE in a feature [message #1721290 is a reply to message #1721287] Tue, 26 January 2016 11:10 Go to previous messageGo to next message
Member
Which - as I've just seen - does not work in case of Oomph install.
Since Oomph installs features in bundle pools the path "${installFolder}/features/...." does not exist of course.
Any ideas anyone?
Re: Bundling JRE in a feature [message #1721308 is a reply to message #1721290] Tue, 26 January 2016 13:02 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 26.01.2016 um 12:10 schrieb Michal Kleczek:
I think it should generally be "${bundlePool}/features/...". In standard "stand-alone" installations the install folder
*is* the bundle pool, so it should work in both cases with shared and with unshared bundle pool.
Cheers
/Eike
http://www.esc-net.de
Re: Bundling JRE in a feature [message #1791843 is a reply to message #1721308] Fri, 06 July 2018 07:39 Go to previous messageGo to next message
Christoph Läubrich is currently offline Christoph LäubrichFriend
I tried to use ${bundlePool} but it seems it is not resolved inside Eclipse Target definition and I get the error that chmod failed because the path could not be found. Is this an error of the target editor or do I got something wrong?
instructions.install=org.eclipse.equinox.p2.touchpoint.eclipse.chmod(targetDir:${bundlePool}/features/<my feature name>/jre/bin,targetFile:java,permissions:755);
[Updated on: Fri, 06 July 2018 07:40]
Re: Bundling JRE in a feature [message #1791881 is a reply to message #1791843] Fri, 06 July 2018 13:06 Go to previous messageGo to next message
The P2 director/tycho also seem to not understand ${bunldePool} is there anything that must be set for this to work?
Re: Bundling JRE in a feature [message #1802228 is a reply to message #1791881] Mon, 04 February 2019 17:58 Go to previous message
loki der quaeler is currently offline loki der quaelerFriend
Did you ever find a resolution to this?
Previous Topic:Neon Repository not accessible?
Next Topic:P2 bundle info gets mangled if RCP or Eclipse install directory is renamed or moved
Current Time: Tue Feb 18 09:10:24 GMT 2020
Powered by FUDForum. Page generated in 0.04237 seconds
