Exception at CoAP Server addEndpoint [message #1720698] |
Wed, 20 January 2016 10:45 |
Ashok Athukuri Messages: 14 Registered: November 2015 |
am trying one of example CoAP server program from Californium Github source file HelloWorldServer.java
I have used library californium-core-1.0.1.jar file
When I run below code to addEndpoints, I get an exception:
private void addEndpoints() {
for (InetAddress addr : EndpointManager.getEndpointManager().getNetworkInterfaces()) {
// only binds to IPv4 addresses and localhost
if (addr instanceof Inet4Address || addr.isLoopbackAddress()) {
System.out.println("addr: "+addr.toString());
InetSocketAddress bindToAddress = new InetSocketAddress(addr, COAP_PORT);
System.out.println("bindToAddress: "+bindToAddress.toString());
addEndpoint(new CoapEndpoint(bindToAddress));
Here is the Exception:
Jan 20, 2016 3:24:58 PM org.eclipse.californium.core.network.config.NetworkConfig createStandardWithFile INFO: Storing standard properties in file Californium.properties
addr: /127.0.0.1 bindToAddress: /127.0.0.1:5683
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/californium/elements/RawDataChannel
at HelloWorldServer.addEndpoints(HelloWorldServer.java:53)
at HelloWorldServer.main(HelloWorldServer.java:34)
Caused by: java.lang.ClassNotFoundException: org.eclipse.californium.elements.RawDataChannel
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 2 more
I tried to clean and rebuild the project still same issue. Created project again, don't work
I see no file in GitHub Source org/eclipse/californium/elements/RawDataChannel.java is that is the problem !?
Thanks in advance
[Updated on: Wed, 20 January 2016 11:23] Report message to a moderator
FUDForum. Page generated in 0.03569 seconds
