Home » Newcomers » Newcomers » ArrayList in Java not giving angular bracket
ArrayList in Java not giving angular bracket [message #1720323] Sun, 17 January 2016 06:34 Go to next message
Jeen P N is currently offline Jeen P NFriend
I am new to programming, and learning JAVA using Eclipse.
The issue is related to ArrayList.
When I select ArrayList - java.util, it imports additional import statement (import java.util.ArrayList;) at the top of the code.
But below the
ArrayList
it does not display the angular bracket/diamond bracket beside the ArrayList as shown in the attached image.
When manually adding <> beside ArrayList, it gives error.
Eclipse Version Installed:
Eclipse Standard/SDK
Version: Kepler Service Release 2
Build id: 20140224-0627
Re: ArrayList in Java not giving angular bracket [message #1720500 is a reply to message #1720323] Tue, 19 January 2016 05:10 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
ArrayList<>, literally like that, isn't a valid type name. I wouldn't expect it to be proposed--why do you?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: ArrayList in Java not giving angular bracket [message #1720547 is a reply to message #1720500] Tue, 19 January 2016 09:05 Go to previous messageGo to next message
I was referring to a Java Certification Course- Lite edition in EdCast.Org
A screenshot is attached for reference.
Re: ArrayList in Java not giving angular bracket [message #1754560 is a reply to message #1720323] Mon, 20 February 2017 09:28 Go to previous message
antonio sarco is currently offline antonio sarcoFriend
Hope this will help you to know more about...ArrayList
Anto
Previous Topic:Is it possible to work with eclipse android "offline"
Next Topic:Does jetty not support DSA public key certificate?
Current Time: Tue Jul 27 08:19:09 GMT 2021
Powered by FUDForum. Page generated in 0.03362 seconds
