Home » Newcomers » Newcomers » Help! Cant fix Java Exit Code 13!(Java Exit Code 13 wont fix)
icon8.gif  Help! Cant fix Java Exit Code 13! [message #1720322] Sun, 17 January 2016 05:37 Go to next message
Tyler Futrell is currently offline Tyler FutrellFriend
Did you also have this problem after upgrading to Win 10?[ 0 votes ]
1.Yes 0 / 0%
2.No 0 / 0%
Hello all, today I decided to get back to Eclipse after a while of a break. But when I run it this error pops up:
index.php/fa/24669/0/
So i went through a few tutorials telling me to set the javaw.exe, i did and nothing changed, so i went into the logs and found:
index.php/fa/24670/0/
Went to try and find anything on this, yet nothing came up.
Any suggestions?
PC Specs:
Windows 10
64-bit
Java jre 1.8.0_66
Thanks!
  • Attachment: Error Code 1.png
    (Size: 36.85KB, Downloaded 1319 times)
  • Attachment: log1.png
    (Size: 13.50KB, Downloaded 1318 times)
Re: Help! Cant fix Java Exit Code 13! [message #1720481 is a reply to message #1720322] Mon, 18 January 2016 21:04 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Did you read the Announcement message at the top of this Newcomers forum, the one that mentions EXIT CODE 13?
Re: Help! Cant fix Java Exit Code 13! [message #1720499 is a reply to message #1720481] Tue, 19 January 2016 05:07 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
If you actually have "####" as part of the path, try avoiding that. You can also try using a less deeply nested installation location, and/or reinstalling your 64-bit Java. If you have a backup of the original eclipse.ini from the zip file, you might try going back to it afterward.
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Any plan of a SDT (Swift Development Toolkit) ?
Next Topic:Eclipse sees Angularjs plugin but not Tern
Current Time: Tue Nov 19 20:32:59 GMT 2019
Powered by FUDForum. Page generated in 0.03000 seconds
