tycho build failing due to missing efxclipse dependencies [message #1720127] |
Thu, 14 January 2016 15:13 |
Ali Karimi Messages: 36 Registered: October 2015 |
Member |
Hey,
currently i am stuck at getting a tycho build of my efxclipse e4 application up and running. I have the usual project structure and a bunch of my own plugins like this:
- test.app
- test.app.product
- test.app.feature
- test.app.releng
- test.app.plugin.1
- test.app.plugin.n
I have added a pom.xml file to each of those projects an the parent pom file resides in the test.app.releng project. I have adjusted the test.app.releng/pom.xml to include the other plugins by adding a corresponding entry in the modules section for each plugin.
The maven build succeeds, the deployment using the ant script in test.app.releng/build.xml also works fine and create en executable of my application. I am also able to start my application. However, i am having several exceptions with Unresolved requirements. Each of them are coming from bundles which should be provided by the target platform, at least i thought they would be.
Anyone an idea of what could be wrong??
Thanks in advance.
Here is the log:
!SESSION 2016-01-14 15:57:21.076 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_60
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
!ENTRY test.app 4 0 2016-01-14 15:57:22.626
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: test.app [6]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.di
-> Bundle-SymbolicName: org.eclipse.e4.ui.di; bundle-version="1.1.0.v20150422-0725"
org.eclipse.e4.ui.di [60]
Unresolved requirement: Require-Bundle: org.eclipse.e4.core.di.extensions; bundle-version="0.9.0"
-> Bundle-SymbolicName: org.eclipse.e4.core.di.extensions; bundle-version="0.13.0.v20150421-2214"; singleton:="true"
org.eclipse.e4.core.di.extensions [57]
Unresolved requirement: Require-Bundle: org.eclipse.osgi.services; bundle-version="3.2.100"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY test.app.base 4 0 2016-01-14 15:57:22.628
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: test.app.base [8]
Unresolved requirement: Import-Package: org.eclipse.fx.core.log
!ENTRY test.app.model 4 0 2016-01-14 15:57:22.628
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: test.app.model [19]
Unresolved requirement: Import-Package: org.eclipse.fx.core.adapter; version="2.2.0"
!ENTRY test.app.services 4 0 2016-01-14 15:57:22.628
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: test.app.services [23]
Unresolved requirement: Import-Package: test.app.plugin.test3
-> Export-Package: test.app.plugin.test3; bundle-symbolic-name="test.app.plugin.test4"; bundle-version="1.0.0.201601141456"; version="0.0.0"
test.app.plugin.test4 [12]
Unresolved requirement: Import-Package: org.eclipse.e4.ui.workbench.lifecycle
-> Export-Package: org.eclipse.e4.ui.workbench.lifecycle; bundle-symbolic-name="org.eclipse.e4.ui.workbench"; bundle-version="1.3.0.v20150531-1948"; version="0.0.0"; x-friends:="org.eclipse.e4.ui.workbench.swt"
org.eclipse.e4.ui.workbench [63]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.services; bundle-version="0.9.0"
-> Bundle-SymbolicName: org.eclipse.e4.ui.services; bundle-version="1.2.0.v20150422-0725"; singleton:="true"
org.eclipse.e4.ui.services [62]
Unresolved requirement: Import-Package: org.osgi.service.event; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.di; bundle-version="0.9.0"
!ENTRY test.app.services.remote 4 0 2016-01-14 15:57:22.630
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: test.app.services.remote [24]
Unresolved requirement: Import-Package: test.app.services.internal.message.validator
-> Export-Package: test.app.services.internal.message.validator; bundle-symbolic-name="test.app.services"; bundle-version="1.0.0.201601141456"; version="0.0.0"
!ENTRY test.app.plugin.test 4 0 2016-01-14 15:57:22.631
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: test.app.plugin.test [25]
Unresolved requirement: Import-Package: test.app.plugin.test2
-> Export-Package: test.app.plugin.test2; bundle-symbolic-name="test.app.plugin.test2"; bundle-version="1.0.0.201601141456"; version="0.0.0"
test.app.plugin.test2 [10]
Unresolved requirement: Import-Package: test.app.model.property
-> Export-Package: test.app.model.property; bundle-symbolic-name="test.app.model"; bundle-version="1.0.0.201601141456"; version="0.0.0"
test.app.model [19]
!ENTRY org.eclipse.e4.core.di.extensions 4 0 2016-01-14 15:57:22.633
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.core.di.extensions [57]
!ENTRY org.eclipse.e4.ui.di 4 0 2016-01-14 15:57:22.633
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.di [60]
!ENTRY org.eclipse.e4.ui.services 4 0 2016-01-14 15:57:22.635
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.services [62]
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-14 15:57:22.636
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.workbench [63]
!ENTRY org.eclipse.equinox.http.jetty 4 0 2016-01-14 15:57:22.638
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.http.jetty [72]
Unresolved requirement: Import-Package: org.eclipse.equinox.http.servlet; version="1.0.0"
-> Export-Package: org.eclipse.equinox.http.servlet; bundle-symbolic-name="org.eclipse.equinox.http.servlet"; bundle-version="1.2.1.v20150828-1818"; version="1.1.0"
org.eclipse.equinox.http.servlet [74]
Unresolved requirement: Import-Package: org.osgi.service.http; version="[1.2.0,1.3.0)"
!ENTRY org.eclipse.equinox.http.servlet 4 0 2016-01-14 15:57:22.638
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.http.servlet [74]
!ENTRY org.eclipse.equinox.ds 4 0 2016-01-14 15:57:22.775
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.ds [80]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.util.event; version="1.0.0"
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
!ENTRY org.eclipse.equinox.event 4 0 2016-01-14 15:57:22.775
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.event [81]
Unresolved requirement: Import-Package: org.osgi.service.event; version="[1.3.0,1.4.0)"
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-14 15:57:23.285
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.log4j.Log4JLoggerFactory. The reference is: Reference[name = registerAppender, interface = org.apache.log4j.Appender, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerAppender, unbind = unregisterAppender, updated = null]
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-14 15:57:23.287
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.ds 1 0 2016-01-14 15:57:24.280
!MESSAGE Could not bind a reference of component test.app.themes.default. The reference is: Reference[name = Stylesheet, interface = org.eclipse.fx.ui.services.theme.Stylesheet, policy = dynamic, cardinality = 0..n, target = null, bind = registerStylesheet, unbind = unregisterStylesheet]
Re: tycho build failing due to missing efxclipse dependencies [message #1720135 is a reply to message #1720130] |
Thu, 14 January 2016 16:06 |
Member |
Thanks for the fast answer:
here it is:
<feature
id="test.app.feature"
label="test Application Feature"
version="1.0.0.qualifier"
provider-name="My comp">
<description url="[url]http://www.efxclipse.org[/url]">
TODO FILL WITH CONTENT
</description>
<copyright url="[url]http://www.efxclipse.org[/url]">
</copyright>
<license url="[url]http://www.efxclipse.org[/url]">
</license>
<plugin
id="org.eclipse.fx.core.log4j"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.fx.core"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.base"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.model"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.services"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.log4j.properties"
download-size="0"
install-size="0"
version="0.0.0"
fragment="true"
unpack="false"/>
<plugin
id="test.app"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.plugin.test"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.plugin.test2"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.plugin.test3"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.plugin.test4"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.services.remote"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="test.app.services.local"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
</feature>
[Updated on: Thu, 14 January 2016 16:12] Report message to a moderator
FUDForum. Page generated in 0.03589 seconds
