Home » Eclipse Projects » Eclipse Platform » Performance problems with marker creation in an custom editor
Performance problems with marker creation in an custom editor [message #1719849] Tue, 12 January 2016 10:07 Go to next message
I'm creating error and warning markers inside of a custom Eclipse editor. The markers are created within an error listener based on the ANTLR parser generator.
The bottleneck however is the creation of markers if many errors or warning are detected and created.
It significantly slows down the performance of the editor.
How can I speed up the marker creation?
Would it be wise to limit the amount of markers?
Or do I need to refactor out the marker creation in a job (collect errors in the listener and then create the markers in a Eclipse job)?
Any advise is appreciated.
Re: Performance problems with marker creation in an custom editor [message #1721409 is a reply to message #1719849] Wed, 27 January 2016 04:11 Go to previous messageGo to next message
Each time you create a marker, a ResourceChange event is sent. If you
create lots of markers, you should do this in a WorkspaceJob so that
these notifications are batched. See here:
https://eclipse.org/articles/Article-Concurrency/jobs-api.html
Re: Performance problems with marker creation in an custom editor [message #1722479 is a reply to message #1721409] Fri, 05 February 2016 03:50 Go to previous message
Hello Felix,
sorry for the late reply. Thank you for your help. I will try that.
Previous Topic:can't create "New android project"
Next Topic:IStartup does not appear to work in Eclipse Mars
Current Time: Wed Apr 23 11:49:02 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
