Home » Modeling » QVT-OML » Keeping xmi:id for migration
Keeping xmi:id for migration [message #1719406] Thu, 07 January 2016 16:43 Go to next message
Francois Le Fevre is currently offline Francois Le FevreFriend
Member
Dear all,
I am new to the QVTo world.
I am facing a difficulty in the SysML composant of Eclipse papyrus project.
I would like to develop a qvto for migrating my initial sysml model in SysML1.1 metamodel into SysML1.4.
First at all: XMI:ID and URI
I would like to keep the initial xmi:id / uri of my initial elements? or do I need to implement a blackbox?
Secundly: switching namespace
The majority elements of the source metamodel have a direct linked with the target metamodel. The only differences is the namespace uri...
So if I have initial element of type Requierement in the namespace SysML 1.1,
is their a qvto transformation/function to switch it directly into a second namespace, (also Requirement but in SysML 1.4 namespace), keeping everything else?
Thanks for your idea.
Francois
Re: Keeping xmi:id for migration [message #1719492 is a reply to message #1719406] Fri, 08 January 2016 10:50 Go to previous messageGo to next message
xmi:ids are an artefact of XMI serialization of your model. If you
persisted your model in a database there might be no xmi:ids to worry about.
xmi:ids are not part of your model and so model transformation tools
ignore them (trash them).
It is possible to use blackboxes to escape to Java and access / enforce
an xmi:id. These facilities might already exist.
However since xmi:ids are not a modeling concrept, it seems a mistake to
pollute the transformation.
IMHO the best approach is to have a deterministic xmi:id generator.
Attached is one of the files for QVT 1.3 whose xmi:ids are auto-generated by
GIT\org.eclipse.qvtd\plugins\org.eclipse.qvt\src\org\eclipse\qvt\tools\Ecore2UML.java
This is invaluable since it ensures that after a *.ecore update the
*.uml has stable xmi:ids and so the Papyrus diagrams are affected only
by the changed parts of the model.
NB the above xmi:id generator is simplistic since the complexity of the
UML in the QVT metmodels is limited.
Another approach that I take, when using UML as my source models, is to
re-assign all the accidental xmi:ids from Papyrus / UML2 so that my
subsequent toolchain sees stable xmi:ids.
See for instance
GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.build\src\org\eclipse\ocl\examples\build\utilities\IdAssigner.java
GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.build\src\org\eclipse\ocl\examples\build\utilities\UMLIDAssigner.java
GIT\org.eclipse.ocl\plugins\org.eclipse.ocl.pivot.uml\src\org\eclipse\ocl\pivot\uml\internal\utilities\UMLXMIID.java
Imposing algorithmically determinate xmi:ids gives you control and some
immunity to metamodel changes such as SysML. But beware that generating
determinate and distinct xmi:ids for the most obscure possibilities of
overloaded operations with nested templates types is non-trivial.
Unfortunately most users only discover the benefit of determinstic
xmi:ids after a legacy of models using indeterminate xmi:ids has been
established.
An alternative approach is to just use the *.qvttrace file from the
transformation execution to identify the input/output pairing. It is
probably less than 20 lines of Java to get all the input xmi:ids and
poke them on to the outputs.
Ed Willink
On 07/01/2016 16:43, Francois Le Fevre wrote:
> Dear all,
> project.
> SysML 1.1, is their a qvto transformation/function to switch it
> Francois
Re: Keeping xmi:id for migration [message #1719507 is a reply to message #1719492] Fri, 08 January 2016 13:22 Go to previous messageGo to next message
Member
Thanks a lot for your quick answer.
I will take time to understand everything since I am newbie.
Nevertheless I have huge difficulty to understand that xmi:id are not part of the model.
If I have two models, MA and MB, store in two xmi file MA.xmi and MB.xmi, where inside MB, bObject references a aObject.
The serialzation will put in MB.xmi a reference to the aObject through its xmi:id , isn't it?
So for me xmi:id were key elements...because they ensure unicity across models.
So My concern is :
if I made a qvto to transform any model of sysml11 metamodel to a compliant sysml14 metamodel without managing xmi:ids,
and if people used it to transformat a initial set X11 of sysml11 models into a X14 set of models in sysml14 at a given time.
then a second group of people Y with a secund set of sysml11 models that reference the initial set of sysml11 models, their models will not work ever even if they use the qvto transformation. because I cannot ensure that xmi:id are not the same...
I will look deeply into your code links.
Francois
Re: Keeping xmi:id for migration [message #1719539 is a reply to message #1719507] Fri, 08 January 2016 17:35 Go to previous message
Your problem is quite common.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=485439 raised.
Ed Willink
> part of the model.
> models.
> So My concern is :
> compliant sysml14 metamodel without managing xmi:ids, and if people used
> Francois
Previous Topic:[QVTo] Transform an object by a condition.
Next Topic:QVTo standalone: EMF package registries w/o maven/testng?
Current Time: Mon Jan 25 23:57:09 GMT 2021
Powered by FUDForum. Page generated in 0.02023 seconds
