Problem Papyrus and stereotype applied [message #1719396] |
Thu, 07 January 2016 15:47 |
Hi guys! Can anyone help please!!!
I developed the profile on papyrus and I am applying in the model. The xmi see that it was applied in the model more when I try to put the stereotype it throws the following mistakes...
I am using it in profile
do
output.applyProfile(thisModule.findProfile('TMDs'));
and it in stereotype
do
output.applyStereotype(thisModule.findStereotype('Pritt'));
I don't know what problem
org.eclipse.m2m.atl.engine.emfvm.VMException
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:51)
at org.eclipse.m2m.atl.engine.emfvm.lib.ExecEnv.terminated(ExecEnv.java:2557)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:210)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.applyDelayedInvocations(UML2ModelAdapter.java:136)
at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:49)
... 12 more
Caused by: java.lang.IllegalArgumentException: profile "TMDs::Fristte" is not applied
at org.eclipse.uml2.uml.internal.operations.ElementOperations.getDefinition(ElementOperations.java:1245)
at org.eclipse.uml2.uml.internal.operations.ElementOperations.applyStereotype(ElementOperations.java:1479)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereotype(ElementImpl.java:511)
... 18 more
FUDForum. Page generated in 0.02696 seconds
