Home » Modeling » Graphiti » Cannot move ContainerShape
Cannot move ContainerShape [message #1719265] Wed, 06 January 2016 16:46 Go to next message
Alex Kravets is currently offline Alex KravetsFriend
I rewrote part of my code to correct some issues and somehow ended up not being able to move my ContainerShape. All I am getting is the marquee rectangle when trying to select and move the shape. FeatureProvider's getMoveShapeFeature() is not being called when I try to move the shape, but is being called when I try to move shapes inside my container. Can anybody offer advice on what would cause this behavior or good place to debug?
Alex
[Updated on: Wed, 06 January 2016 16:53]
Report message to a moderator
Re: Cannot move ContainerShape [message #1719702 is a reply to message #1719265] Mon, 11 January 2016 15:12 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Alex,
hm, I can only guess, but maybe your container shape is not active?
HTH,
Michael
Re: Cannot move ContainerShape [message #1720171 is a reply to message #1719702] Thu, 14 January 2016 21:19 Go to previous messageGo to next message
Michael,
No, the container shape is active.
Here is part of the code that was changed:
ContainerShape containerShape = peCreateService.createContainerShape(context.getTargetContainer(), true);
MapperUtil.addProperty(containerShape, MapperConstans.CONTAINER_TYPE, MapperConstans.INVISIBLE_CONTAINER_TYPE);
Rectangle invisibleContainer = createService.createInvisibleRectangle(containerShape);
gaService.setLocationAndSize(invisibleContainer, context.getX(), context.getY(), width, 60);
RoundedRectangle roundedRectangle = createService.createRoundedRectangle(invisibleContainer, 10, 10);
roundedRectangle.setBackground(manageColor(IColorConstant.WHITE));
roundedRectangle.setLineWidth(3);
//containerShape.setStyle(StyleUtil.getStyleForChannelComponentContainer(getDiagram()));
layoutService.setLocationAndSize(roundedRectangle, 5, 5, width-10, 50);
link(containerShape, context.getNewObject());
peCreateService.createChopboxAnchor(containerShape);
if(hasIncomingConnection()){
   createAnchor(containerShape, roundedRectangle, AnchorLocation.LEFT);
if(hasOutgoingConnection()){
   createAnchor(containerShape, roundedRectangle, AnchorLocation.RIGHT);
layoutPictogramElement(containerShape);
return containerShape;
And here is a video I recorded to further show the issue
http://i.imgur.com/b3Df2Oe.gif
As you can see I can't move the main container itself, but I can execute code inside MoveFeature when trying to move containers inside the main container.
Re: Cannot move ContainerShape [message #1720437 is a reply to message #1720171] Mon, 18 January 2016 16:08 Go to previous messageGo to next message
Hm, do you have any special coding in your tool behavior provider?
Michael
Re: Cannot move ContainerShape [message #1720594 is a reply to message #1720437] Tue, 19 January 2016 15:22 Go to previous message
Yes! That was the problem. I overrode getSelection() method in behavior provider and logic was messing up the selection of the main figure. Thank you for your help Michael!
Previous Topic:Call add feature from within a custom feature
Next Topic:Cancelling model changes done in a CustomFeature
Current Time: Tue Feb 18 09:08:27 GMT 2020
Powered by FUDForum. Page generated in 0.05671 seconds
