Home » Newcomers » Newcomers » eclipse version for mac os 10.6?
Re: eclipse version for mac os 10.6? [message #1719180 is a reply to message #1719178] |
Tue, 05 January 2016 22:14 |
On 01/05/2016 02:06 PM, keni lu wrote:
> Updating the system isn't a great choice right now -- everything works,
> the change post- OS 10.6 is substantial, and the machine isn't very fast
> anyway.
> So -- if I *don't* have Java 7, does someone know what the newest
> version of Eclipse is that I can run?
> (And, yes, the problem is that Apple doesn't provide a newer Java for
> this old OS, and neither does Oracle provide an installer. I think there
> are workarounds to get a newer JDK on my machine, but that's definitely
> not my first choice.)
There's an option to back up to an Eclipse version that will work on
Java 6. I think the latest one would have been Indigo (or maybe Juno
too, but I don't think so). Indigo was a great release. Depending on
what you plan to do, you may be quite satisfied with it.
Re: eclipse version for mac os 10.6? [message #1719280 is a reply to message #1719180] |
Wed, 06 January 2016 18:42 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
The Eclipse installer requires at least Java 1.7, there are no older versions of it that will work with 1.6. But I think Mars was the first release that had a hard requirement for 1.7+, so you should be able to download a Luna package and use that (Eclipse package releases are in alphabetical order by year, eg Indigo=2011, Juno=2012, Kepler=2013, Luna=2014, Mars=2015, Neon=2016...)
https://www.eclipse.org/downloads/packages/release/luna/sr2
Just extract the archive of one of those downloads into a local user directory and run the eclipse executable. If that doesn't work, follow the instructions to point eclipse.ini to your installation of JDK.
[Updated on: Wed, 06 January 2016 18:45] Report message to a moderator
Current Time: Thu Apr 25 15:48:18 GMT 2024
Powered by FUDForum. Page generated in 0.11514 seconds
