Home » Newcomers » Newcomers » Problem with color themes
Problem with color themes [message #1719168] Tue, 05 January 2016 17:49 Go to next message
Victor Valencia is currently offline Victor ValenciaFriend
I am running Eclipse on an Ubuntu VM in VirtualBox. I have added the color theme package but the colorization does not seem to be working. When I selected a theme and activated it the editor window changed to black background and white text but that's it. I have tried other themes and they all have the same issue.
Anyone have any ideas?
Victor
Re: Problem with color themes [message #1719169 is a reply to message #1719168] Tue, 05 January 2016 18:31 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> Victor
You'll find that on Linux, system color themes play a huge role too. The
variables are too many to explain here and I don't know them all. What I
did back in the day was to use a theme named ClearLooks on Ubuntu. (I
don't know what that's called today nor how to set it up on modern
Ubuntu versions--Google is your friend.)
If you like a black editor background, as you appear to, then by all
means keep the Eclipse Color Theme plug-in.
The main objection is that in some status windows, background colors
make messages, status, etc. unreadable. As I've described it here, I
found a solution that worked fine.
Hope this helps.
Re: Problem with color themes [message #1719273 is a reply to message #1719169] Wed, 06 January 2016 17:55 Go to previous message
Thanks for the help Russell. It turns out that I had an incompatible version of the CDT. I re-installed using the pre-packaged
version including CDT and things are better now. The problem now is settling on which color scheme Smile
Victor
Previous Topic:FindBugs
Next Topic:error accessing javascript file
Current Time: Tue Jun 02 15:50:26 GMT 2020
Powered by FUDForum. Page generated in 0.03260 seconds
