Home » Modeling » Compare » [EMF Compare] Custom IComparisonScope in IDE
[EMF Compare] Custom IComparisonScope in IDE [message #1718980] Mon, 04 January 2016 08:51 Go to next message
Rolf Theunissen is currently offline Rolf TheunissenFriend
Dear all,
Is it possible to use a custom comparison scope instead of the DefaultComparisonScope in the IDE? If possible, are there any leads of which code needs to be adapted?
I need to prune the scope for the comparison to skip some elements that will never match.
Kind Regards,
Rolf
Re: [EMF Compare] Custom IComparisonScope in IDE [message #1719226 is a reply to message #1718980] Wed, 06 January 2016 11:14 Go to previous message
Philip Langer is currently offline Philip LangerFriend
Member
Hi Rolf,
afaik, it is currently only possible to use a custom implementation of the IComparisonScope when you invoke EMF Compare using the API. There is no extension point that allows to replace the default comparison scope when EMF Compare is invoked through the compare UI.
If your main goal is to ignore certain parts of your model in the matching phase, you could do that in a customized match engine instead (see how to override the default match engine).
Hope this helps,
Philip
Philip Langer
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:[EMF Compare] Extension Points for configuring phases not working
Next Topic:Comparing two xmi files?
Current Time: Tue May 11 08:09:00 GMT 2021
Powered by FUDForum. Page generated in 0.01916 seconds
